I've tried a few variations on setenv usage, including:
thufir@dur:~/powershell/helloPSTwitterAPI$
thufir@dur:~/powershell/helloPSTwitterAPI$ setenv ApiKey="57647625454354365"
Command 'setenv' not found, did you mean:
command 'getenv' from snap getenv (0.3.0)
See 'snap info <snapname>' for additional versions.
thufir@dur:~/powershell/helloPSTwitterAPI$ man setenv | cat
SETENV(3) Linux Programmer's Manual SETENV(3)
NAME
setenv - change or add an environment variable
SYNOPSIS
#include <stdlib.h>
int setenv(const char *name, const char *value, int overwrite);
int unsetenv(const char *name);
Feature Test Macro Requirements for glibc (see feature_test_macros(7)):
setenv(), unsetenv():
_POSIX_C_SOURCE >= 200112L
|| /* Glibc versions <= 2.19: */ _BSD_SOURCE
DESCRIPTION
The setenv() function adds the variable name to the environment with
the value value, if name does not already exist. If name does exist in
the environment, then its value is changed to value if overwrite is
nonzero; if overwrite is zero, then the value of name is not changed
(and setenv() returns a success status). This function makes copies of
the strings pointed to by name and value (by contrast with putenv(3)).
The unsetenv() function deletes the variable name from the environment.
If name does not exist in the environment, then the function succeeds,
and the environment is unchanged.
RETURN VALUE
The setenv() function returns zero on success, or -1 on error, with
errno set to indicate the cause of the error.
The unsetenv() function returns zero on success, or -1 on error, with
ERRORS
EINVAL name is NULL, points to a string of length 0, or contains an '='
character.
ENOMEM Insufficient memory to add a new variable to the environment.
ATTRIBUTES
For an explanation of the terms used in this section, see
attributes(7).
│Interface │ Attribute │ Value │
│setenv(), │ Thread safety │ MT-Unsafe const:env │
│unsetenv() │ │ │
CONFORMING TO
POSIX.1-2001, POSIX.1-2008, 4.3BSD.
NOTES
POSIX.1 does not require setenv() or unsetenv() to be reentrant.
Prior to glibc 2.2.2, unsetenv() was prototyped as returning void; more
recent glibc versions follow the POSIX.1-compliant prototype shown in
the SYNOPSIS.
BUGS
POSIX.1 specifies that if name contains an '=' character, then setenv()
should fail with the error EINVAL; however, versions of glibc before
2.3.4 allowed an '=' sign in name.
SEE ALSO
clearenv(3), getenv(3), putenv(3), environ(7)
COLOPHON
This page is part of release 4.16 of the Linux man-pages project. A
description of the project, information about reporting bugs, and the
latest version of this page, can be found at
https://www.kernel.org/doc/man-pages/.
GNU 2017-09-15 SETENV(3)
What's the correct way to set this environment variable directly from bash?
