How do I make foo an environment variable accessible through printenv on bash?
PS /home/thufir/powershell/helloPSTwitterAPI>
PS /home/thufir/powershell/helloPSTwitterAPI> $env:foo = 'x' * 333 + '!'
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx!
I would like to use powershell to set an environment variable rather than using setenv itself so that Visual Studio Code, and bash, will pick up the variables when running powershell scripts.
Thufir
  • 4,631
I would do it as described below:
[System.Environment]::SetEnvironmentVariable('DOCKER_HOST','docker.artofshell.com')
See also
This way the environment variable (in this case DOCKER_HOST) is created permanently as if you would've created it via the windows control panel.
Jonas
  • 554
