EDIT 2: After nearly 3 days of troubleshooting and reinstalling Ubuntu I am close to giving up and sending my laptop back. If anyone is looking to buy a new laptop and wants to run Ubuntu on it I would strongly recommend avoiding the Lenovo X1 Carbon Gen 7.
EDIT 1: I don't think this has anything to do with the reboot process per se. After running sudo apt upgrade without hitting reboot, it seems I am on the same kernel of 5.0.0-23-generic. So for some reason the kernel won't update. However, after the reboot process, if I run sudo apt upgrade after rebooting, it will re-install the same packages again.
OP: I was told on this post (No WiFi Adaptor found, Lenovo X1 Carbon Gen 7 (version 18.04 & 19.10)) to ask another question on the forum. The original problem I was having was that my WiFi panel said "No WiFi Adapter Found". So it was recommended that I update my kernel with the commands sudo apt update and sudo apt upgrade and my firmware with (http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.173.12_all.deb) and installing with sudo dpkg -i linux*.deb
When I enter these commands to upgrade my kernel and firmware install in the terminal they do not have an effect on the kernel. I tried running them twice and they seem to have installed all required packages, however uname -a still shows I'm on the old kernel of 5.0.0-23-generic. However after reboot I have to install the packages again, as if nothing was installed before. I am definitely not running on a live OS because I can boot up without USB. Also I was installing them on my phone's bluetooth connection which gets disconnected as soon as the install is finished.
Here is what I did in order when I was originally installing: Power on -> Pressed Enter to disrupt normal startup -> Pressed F12 to enter boot menu -> on boot menu, selectedUSB HDD: SMI USB DISK -> on grub, selected Install Linux
