UPDATE since my kernel and firmware updates weren't saving on reboot I moved the question to here: (Terminal commands not saving on reboot. Lenovo X1 Carbon Gen 7, Ubuntu 18.04)
I am having the same issue as this post (No WiFi Adaptor found in Lenovo X1 Carbon Generation 7), however nothing suggested in the post has worked so far. It looks like the solution is to upgrade my firmware from -43 to -46 but I have no idea how to do that. See the output I have posted below.
I originally installed 18.04 LTS on my brand new Lenovo x1 Carbon Gen 7. My WiFi card is Intel(R) Wireless AC 9650 160MHz. Currently I am not able to connect to WiFi, and my WiFi Panel says "No WiFi Adaptor Found". These are the things I have done so far:
- Disabled Secure Boot
- Followed the instructions in this video (https://www.youtube.com/watch?v=dokG4bCF4GQ)
- Followed the instructions in the top comment of this post (No WiFi Adaptor found in Lenovo X1 Carbon Generation 7)
- Upgraded to Ubuntu 19.10 as the OP did in this post (No WiFi Adaptor found in Lenovo X1 Carbon Generation 7)
- Reinstalled Ubuntu 18.04 (my current version)
- Tried installing the driver for my wifi card in /lib/firmware (https://www.intel.com/content/www/us/en/support/articles/000005511/network-and-i-o/wireless-networking.html)
Please let me know what I can do to fix this. I have spent the last 3 days trying to troubleshoot this issue and nothing seems to work, I am pretty frustrated.
Output of lspci -knn | grep Net -A3; rfkill list
00:14.3 Network controller [0280]: Intel Corporation Device [8086:02f0]
Subsystem: Intel Corporation Device [8086:0030]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Output of dmesg | grep iwl
[ 2.305197] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 2.323471] iwlwifi 0000:00:14.3: loaded firmware version 43.95eb4e97.0 op_mode iwlmvm
[ 2.352746] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x354
[ 7.381803] iwlwifi 0000:00:14.3: Failed to load firmware chunk!
[ 7.381815] iwlwifi 0000:00:14.3: iwlwifi transaction failed, dumping registers
[ 7.381820] iwlwifi 0000:00:14.3: iwlwifi device config registers:
[ 7.381874] iwlwifi 0000:00:14.3: 00000000: 02f08086 00100406 02800000 00800000 ea238004 00000000 00000000 00000000
[ 7.381882] iwlwifi 0000:00:14.3: 00000020: 00000000 00000000 00000000 00308086 00000000 000000c8 00000000 000001ff
[ 7.381886] iwlwifi 0000:00:14.3: iwlwifi device memory mapped registers:
[ 7.381925] iwlwifi 0000:00:14.3: 00000000: 00489004 00000040 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.381932] iwlwifi 0000:00:14.3: 00000020: 00000011 0c040005 00000351 d55555d5 d55555d5 d55555d5 80008040 001f0040
[ 7.381952] iwlwifi 0000:00:14.3: Could not load the [0] uCode section
[ 7.381980] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -110
[ 7.381987] iwlwifi 0000:00:14.3: Collecting data: trigger 15 fired.
[ 7.608162] iwlwifi 0000:00:14.3: Failing on timeout while stopping DMA channel 8 [0x0bad1122]
[ 7.620281] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
Output of dmesg | grep iwl DOES NOT CHANGE after I run
cd "$(xdg-user-dir DESKTOP)"
sudo dpkg -i linux*.deb
OR
sudo apt update
sudo apt upgrade
EDIT: to those of you who are suggesting this post (No WiFi Adaptor found in Lenovo X1 Carbon Generation 7), none of the solutions work there. I have tried them all. The problem right now seems to be that nothing in terminal is saving on reboot.
