Everything goes fine, but in the end I get this error every time one the GUI install as well as in terminal:
Mounting target filesystem...
Applying workaround to prevent 64-bit systems with big primary memory from being unresponsive during copying files.
Copying files from source media...
Installing GRUB bootloader for legacy PC booting support...
Installing for i386-pc platform.
Installation finished. No error reported.
Installing custom GRUB config for legacy PC booting...
Resetting workaround to prevent 64-bit systems with big primary memory from being unresponsive during copying files.
/usr/bin/woeusb: line 1676: echo: write error: Invalid argument
The command "exit 0" failed with exit status "1", program is prematurely aborted
Any suggestions to solve this?
