I'm following https://wiki.ubuntu.com/DebuggingKernelSuspend and it says that I have to reboot the system with
sudo sh -c "sync && echo 1 > /sys/power/pm_trace && pm-suspend"
and find the lines that says hash matches in dmesg rigth after reboot (what does that mean?)
Well, I found two:
[ 3.583591] ima: Allocated hash algorithm: sha1
[ 3.593050] input: AT Raw Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 3.638808] Magic number: 0:929:176
[ 3.638867] acpi device:39: hash matches
[ 3.638893] acpi device:0c: hash matches
[ 3.639073] rtc_cmos 00:01: setting system clock to 2016-01-01 12:09:51 UTC (1451650191)
Looks like the problem is in these two acpi devices. The article doesn't say what to do in this case. If the problem was in a PCIe device I could simply unload its module, but what should I do in this case? Does an acpi device have a module? If so, how to find its module? And what hash matches mean?
UPDATE:
Here's my lspci:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #3 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1e.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #0 (rev 21)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
3b:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961
UPDATE:
[lz@dom0 tmp]$ lspci -t
-[0000:00]-+-00.0
+-02.0
+-14.0
+-14.2
+-15.0
+-15.1
+-16.0
+-1c.0-[01]----00.0
+-1c.4-[02-3a]--
+-1d.0-[3b]----00.0
+-1e.0
+-1f.0
+-1f.2
+-1f.3
\-1f.4
UPDATE:
dmesg | grep -i acpi
0.000000] Xen: [mem 0x000000006e503000-0x000000006e503fff] ACPI NVS
[ 0.000000] Xen: [mem 0x000000007a3d9000-0x000000007a444fff] ACPI data
[ 0.000000] Xen: [mem 0x000000007a445000-0x000000007abfefff] ACPI NVS
[ 0.000000] efi: ESRT=0x7b226f18 ACPI=0x7a3ee000 ACPI 2.0=0x7a3ee000 SMBIOS=0x7b210000 SMBIOS 3.0=0x7b20f000
[ 1.069765] ACPI: Early table checksum verification disabled
[ 1.069772] ACPI: RSDP 0x000000007A3EE000 000024 (v02 ALASKA)
[ 1.069782] ACPI: XSDT 0x000000007A3EE0B0 0000E4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 1.069821] ACPI: FACP 0x000000007A414898 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 1.069889] ACPI: DSDT 0x000000007A3EE228 02666B (v02 ALASKA A M I 01072009 INTL 20160422)
[ 1.069903] ACPI: FACS 0x000000007ABE6C40 000040
[ 1.069916] ACPI: APIC 0x000000007A4149B0 000084 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 1.069930] ACPI: FPDT 0x000000007A414A38 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 1.069943] ACPI: MCFG 0x000000007A414A80 00003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 1.069957] ACPI: FIDT 0x000000007A414AC0 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 1.069970] ACPI: MSDM 0x000000007A414B60 000055 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 1.069984] ACPI: SSDT 0x000000007A414BB8 003154 (v02 SaSsdt SaSsdt 00003000 INTL 20160422)
[ 1.070007] ACPI: HPET 0x000000007A417D10 000038 (v01 INTEL KBL-ULT 00000001 MSFT 0000005F)
[ 1.070021] ACPI: SSDT 0x000000007A417D48 000E3B (v02 INTEL Ther_Rvp 00001000 INTL 20160422)
[ 1.070034] ACPI: SSDT 0x000000007A418B88 0006BB (v02 INTEL xh_OEMBD 00000000 INTL 20160422)
[ 1.070048] ACPI: UEFI 0x000000007A419248 000042 (v01 INTEL EDK2 00000002 01000013)
[ 1.070062] ACPI: SSDT 0x000000007A419290 000EDE (v02 CpuRef CpuSsdt 00003000 INTL 20160422)
[ 1.070075] ACPI: LPIT 0x000000007A41A170 000094 (v01 INTEL KBL-ULT 00000000 MSFT 0000005F)
[ 1.070089] ACPI: WSMT 0x000000007A41A208 000028 (v01 INTEL KBL-ULT 00000000 MSFT 0000005F)
[ 1.070102] ACPI: SSDT 0x000000007A41A230 00029F (v02 INTEL sensrhub 00000000 INTL 20160422)
[ 1.070116] ACPI: SSDT 0x000000007A41A4D0 003002 (v02 INTEL PtidDevc 00001000 INTL 20160422)
[ 1.070130] ACPI: DBGP 0x000000007A41D4D8 000034 (v01 INTEL 00000002 MSFT 0000005F)
[ 1.070143] ACPI: DBG2 0x000000007A41D510 000054 (v00 INTEL 00000002 MSFT 0000005F)
[ 1.070157] ACPI: BGRT 0x000000007A41D568 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 1.070171] ACPI: RMAD 0x000000007A41D5A0 000114 (v01 INTEL KBL 00000001 INTL 00000001)
[ 1.070185] ACPI: SSDT 0x000000007A41D6B8 00054D (v01 TbtGfx TbtGfx 00001000 INTL 20160422)
[ 1.070198] ACPI: TPM2 0x000000007A41DC08 000034 (v03 Tpm2Tabl 00000001 AMI 00000000)
[ 1.070212] ACPI: ASF! 0x000000007A41DC40 0000A0 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 1.070249] ACPI: Local APIC address 0xfee00000
[ 2.173665] ACPI: PM-Timer IO Port: 0x1808
[ 2.173672] ACPI: Local APIC address 0xfee00000
[ 2.173707] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 2.173708] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 2.173710] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 2.173711] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 2.173762] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 2.173765] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 2.173769] ACPI: IRQ0 used by override.
[ 2.173771] ACPI: IRQ9 used by override.
[ 2.173780] Using ACPI (MADT) for SMP configuration information
[ 2.173784] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 2.352646] ACPI: Core revision 20180810
[ 2.371112] ACPI BIOS Warning (bug): Incorrect checksum in table [BGRT] - 0xDC, should be 0x84 (20180810/tbprint-177)
[ 2.379908] PM: Registering ACPI NVS region [mem 0x6e503000-0x6e503fff] (4096 bytes)
[ 2.379908] PM: Registering ACPI NVS region [mem 0x7a445000-0x7abfefff] (8101888 bytes)
[ 2.380709] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 2.380710] ACPI: bus type PCI registered
[ 2.459664] ACPI: Added _OSI(Module Device)
[ 2.459664] ACPI: Added _OSI(Processor Device)
[ 2.459665] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 2.459666] ACPI: Added _OSI(Processor Aggregator Device)
[ 2.459667] ACPI: Added _OSI(Linux-Dell-Video)
[ 2.459667] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 2.499998] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 2.505360] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2.511690] ACPI: Dynamic OEM Table Load:
[ 2.511696] ACPI: SSDT 0xFFFF88818180E800 0006F6 (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
[ 2.512125] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[ 2.513777] ACPI: Dynamic OEM Table Load:
[ 2.513781] ACPI: SSDT 0xFFFF888180CE5C00 0003FF (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
[ 2.514667] ACPI: Dynamic OEM Table Load:
[ 2.514671] ACPI: SSDT 0xFFFF888180F43800 00065C (v02 PmRef ApIst 00003000 INTL 20160422)
[ 2.515347] ACPI: Dynamic OEM Table Load:
[ 2.515351] ACPI: SSDT 0xFFFF888180D50600 00018A (v02 PmRef ApCst 00003000 INTL 20160422)
[ 2.516841] ACPI: EC: EC started
[ 2.516842] ACPI: EC: interrupt blocked
[ 2.516872] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[ 2.516873] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 2.516874] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[ 2.516875] ACPI: Interpreter enabled
[ 2.516908] ACPI: (supports S0 S3 S5)
[ 2.516909] ACPI: Using IOAPIC for interrupt routing
[ 2.516948] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 2.518072] ACPI: Enabled 7 GPEs in block 00 to 7F
[ 2.521961] ACPI: Power Resource [WRST] (on)
[ 2.522316] ACPI: Power Resource [WRST] (on)
[ 2.522680] ACPI: Power Resource [WRST] (on)
[ 2.523031] ACPI: Power Resource [WRST] (on)
[ 2.523381] ACPI: Power Resource [WRST] (on)
[ 2.523735] ACPI: Power Resource [WRST] (on)
[ 2.524082] ACPI: Power Resource [WRST] (on)
[ 2.524542] ACPI: Power Resource [WRST] (on)
[ 2.524902] ACPI: Power Resource [WRST] (on)
[ 2.525259] ACPI: Power Resource [WRST] (on)
[ 2.525610] ACPI: Power Resource [WRST] (on)
[ 2.525970] ACPI: Power Resource [WRST] (on)
[ 2.526323] ACPI: Power Resource [WRST] (on)
[ 2.526633] ACPI: Power Resource [WRST] (on)
[ 2.526983] ACPI: Power Resource [WRST] (on)
[ 2.527330] ACPI: Power Resource [WRST] (on)
[ 2.527684] ACPI: Power Resource [WRST] (on)
[ 2.529007] ACPI: Power Resource [WRST] (on)
[ 2.529360] ACPI: Power Resource [WRST] (on)
[ 2.529716] ACPI: Power Resource [WRST] (on)
[ 2.542041] ACPI: Power Resource [FN00] (off)
[ 2.542129] ACPI: Power Resource [FN01] (off)
[ 2.542211] ACPI: Power Resource [FN02] (off)
[ 2.542294] ACPI: Power Resource [FN03] (off)
[ 2.542378] ACPI: Power Resource [FN04] (off)
[ 2.543548] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 2.543553] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 2.543596] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 2.562396] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562462] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 2.562525] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562588] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562655] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562718] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562779] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.562841] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 2.563595] ACPI: EC: interrupt unblocked
[ 2.563621] ACPI: EC: event unblocked
[ 2.563639] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 2.563640] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[ 2.563765] ACPI: bus type USB registered
[ 2.580383] PCI: Using ACPI for IRQ routing
[ 2.627863] pnp: PnP ACPI init
[ 2.628141] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.628280] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 2.628317] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 2.629513] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.629566] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.629937] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.631187] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.632238] pnp: PnP ACPI: found 7 devices
[ 3.392469] ACPI: AC Adapter [AC0] (on-line)
[ 3.392539] ACPI: Lid Switch [LID0]
[ 3.392581] ACPI: Sleep Button [SLPB]
[ 3.392621] ACPI: Power Button [PWRB]
[ 3.392663] ACPI: Power Button [PWRF]
[ 3.455097] ACPI: Thermal Zone [TZ00] (28 C)
[ 3.455324] ACPI: Thermal Zone [TZ01] (30 C)
[ 3.461779] hpet_acpi_add: no address or irqs in _CRS
[ 3.566006] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 3.644076] acpi LNXCPU:06: hash matches
[ 5.082551] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 16.887708] xen_acpi_processor: Uploading Xen processor PM info
UPDATE:
wifi/ethernet problems? No
is your battery/power behaving okay? perfectly
do you have external USB devices connected? no
have you noticed other issues? nothing at all
is there an update for your BIOS? I'm gonna have to install Windows and check, this is going to take a while
