I've got fancontrol installed, and immediately after running pwmconfig, I get a Configuration appears to be outdated, please run pwmconfig again message.
This is a an old Dell PC (i5-2320) that I put Ubuntu 16.04 on. Some outputs:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +35.0°C  (high = +80.0°C, crit = +99.0°C)
Core 0:         +35.0°C  (high = +80.0°C, crit = +99.0°C)
Core 1:         +26.0°C  (high = +80.0°C, crit = +99.0°C)
Core 2:         +33.0°C  (high = +80.0°C, crit = +99.0°C)
Core 3:         +31.0°C  (high = +80.0°C, crit = +99.0°C)
dell_smm-virtual-0
Adapter: Virtual device
Processor Fan:   3193 RPM
Motherboard Fan:    0 RPM
$ sudo find /sys -name hwmon
/sys/devices/virtual/hwmon
/sys/devices/platform/coretemp.0/hwmon
/sys/class/hwmon
$ sudo pwmconfig
#pwmconfig revision 6243 (2014-03-20)
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
Found the following devices:
   hwmon0 is coretemp
   hwmon1 is dell_smm
Found the following PWM controls:
   hwmon1/pwm1           current value: 255
   hwmon1/pwm2           current value: 255
Giving the fans some time to reach full speed...
Found the following fan sensors:
   hwmon1/fan1_input     current speed: 3191 RPM
   hwmon1/fan2_input     current speed: 0 ... skipping!
Warning!!! This program will stop your fans, one at a time,
for approximately 5 seconds each!!!
This may cause your processor temperature to rise!!!
If you do not want to do this hit control-C now!!!
Hit return to continue:
Testing pwm control hwmon1/pwm1 ...
  hwmon1/fan1_input ... speed was 3191 now 997
    It appears that fan hwmon1/fan1_input
    is controlled by pwm hwmon1/pwm1
Would you like to generate a detailed correlation (y)? n
Testing pwm control hwmon1/pwm2 ...
  hwmon1/fan1_input ... speed was 3191 now 3202
    no correlation
No correlations were detected.
There is either no fan connected to the output of hwmon1/pwm2,
or the connected fan has no rpm-signal connected to one of
the tested fan sensors. (Note: not all motherboards have
the pwm outputs connected to the fan connectors,
check out the hardware database on http://www.almico.com/forumindex.php)
Did you see/hear a fan stopping during the above test (n)? n
Testing is complete.
Please verify that all fans have returned to their normal speed.
The fancontrol script can automatically respond to temperature changes
of your system by changing fanspeeds.
Do you want to set up its configuration file now (y)? n
$ more /etc/fancontrol
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=*devices/virtual*
DEVNAME=hwmon0=coretemp hwmon1=dell_smm
FCTEMPS=hwmon1/pwm1=hwmon0/temp1_input
FCFANS=hwmon1/pwm1=hwmon1/fan1_input
MINTEMP=hwmon1/pwm1=30
MAXTEMP=hwmon1/pwm1=60
MINSTART=hwmon1/pwm1=150
MINSTOP=hwmon1/pwm1=0
MAXPWM= hwmon1/pwm1=255
I started with an autogen config, but when I couldn't start fancontrol did a few things - removed all references to pwm2 because all I have is a single cpu fan I'm trying to control... and I added the value behind hwmon1 (in italics) myself because there was nothing there before. Even if I accept the values when running fan control I get
$ sudo fancontrol
Loading configuration from /etc/fancontrol ...
Common settings:
  INTERVAL=10
Settings for hwmon1/pwm1:
  Depends on hwmon0/temp1_input
  Controls hwmon1/fan1_input
  MINTEMP=30
  MAXTEMP=60
  MINSTART=150
  MINSTOP=0
  MINPWM=0
  MAXPWM=255
Device path of hwmon1 has changed
What is odd is that the detailed correlation in pwmconfig will change the fan speed, so it seems like it should have everything needed... but I still had to put values in DEVPATH for hwmon1. It seems like it should be comparing the DEVPATH values to something, but I cannot figure out what. Again, this problem is all in the same session, I haven't rebooted. Got any ideas?
jds62f
  • 13
The devices are located in /sys/devices/platform/. You don't actually need DEVPATH, you can put the full path with a wildcard if the hwmon number changes.
Locate where each device is /sys/devices/platform/<kernel_module>/hwmon/<hwmon#>
Edit /etc/fancontrol manually.
Remove DEVPATH and DEVNAME
Replace each entry with the full path from /sys/devices/platform/<kernel_module>/hwmon/hwmon[[:print:]]*
Your =hwmon0/temp1_input would become =/sys/devices/platform/coretemp.0/hwmon/hwmon[[:print:]]*, you just need to get the path for all the hwmon1 entries and replace it.
Once you have it working make a backup of the config in case it gets overwritten or if you update your OS. Here's a thread with some help for manual configuration of fancontrol: Cannot configure Fan Speed with pwmconfig!
rtaft
  • 1,920
