My LG gram 15 laptop runs Ubuntu 16.04. When I was running both Makefile and gradle simultaneously, it was getting slower and slower, and finally it froze, so, I rebooted my laptop. Then it started to print only:
/dev/sda2: clean, ***/*** files, ***/*** blocks
Where the *** are large numbers.
CLI mode works well, but I couldn't start the Ubuntu in GUI mode (lightdm, GNOME...)
I searched for a solution. I read almost every relevant answer about this problem, but none of them worked. I tried to reinstall the Nvidia driver, but my computer doesn't have an Nvidia graphics card.
Results of df -h --exclude=tmpfs --exclude=squashfs :
Filesystem | size | Used | Avail | Use% | Mounted on
udev |0 | 12G | 0% | /dev
/dev/sda2 | 468G | 173G | 272G | 39% | /
/dev/sda1 | 511M | 6.1M | 505M | 2% | /boot/efi
I typed grep EE /var/log/Xorg.0.log suggestion on recovery mode.
$ grep EE /var/log/Xorg.0.log
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
(EE) Failed to load module "fbdev" (module does not exist, 0)
(EE) Failed to load module "vesa" (module does not exist, 0)
/dev/dri/card0: failed to set DRM interface version 1.4: Permission denied.
After I typed Xorg -configure
List of video drivers:
amdgpu
ati
intel
nouveau
qxl
radeon
vmware
odsetting
fbdev
vesa
using config file: "/root/xorg.conf.new"
using system config directory "usr/share/X11/xorg.conf.d"
Number of created screens does not match number of detected devices
Configuration failed
Server terminated with error (2). closing log file.
stratx makes below error:
systemd-logind : failed to get session: PID 962 does not belong to any known session
open /dev/dri/card0: No such file or directory
Screen 0 deleted because of no matching config section.
AIGLX: reverting to software rendering
"journalctl -xe -p err -k"
Couldn't get size: 0x8000000000000000e
MODSIGN: Couldn't get UEFI db list
ip_local_port_range: prefer different parity for start/end values.
Something spring to my mind is that, I forced power off my laptop while It was connected to external monitor via HDMI cable.
