In this version of ubuntu, pulseaudio is a service started for the user. The different commands tried
> pulseaudio -k
> systemctl --user stop pulseaudio
> changing pulse.conf to include autospawn=no
> systemctl daemon-reload
> pkill -9 pulseaudio
It respawns all the time because systemd restarts it. Should i kill the systemd --user instance or is there something else that is tweakable?
placid chat
  • 201
You need to stop the systemd user socket.
systemctl --user stop pulseaudio.socket
systemctl --user stop pulseaudio.service
You can also use the disable, enable, reload, and restart commands as well. That should stop pulseaudio from respawning until you start it back up. Hope that helps
Disabling the service doesn't work. You have to also mask it:
systemctl --user disable pulseaudio.socket
systemctl --user disable pulseaudio.service
systemctl --user mask pulseaudio.socket
systemctl --user mask pulseaudio.service
CpnCrunch
  • 141
You need to find out what else depends on pulseaudio and kill/stop those before stopping pulseaudio.
systemctl --user --reverse list-dependencies pulseaudio
See also: https://askubuntu.com/a/816378/145907
smac89
  • 1,085
