I've just switched to using Lubuntu 19.04 and I am having problems getting keyboard shortcuts working how I like. I have assigned Super+n to switch desktops. However the new setting doesn't take effect. There is some other behaviour overriding my settings which causes Super+n to cycle between application groups. I can't find the settings to change this anywhere.
DK Bose
  • 44,553
Brian
  • 131
Don't use the Super key as the sole modifier key. Use Alt+Super or Ctrl+Super. So, in your case, use something like Ctrl+Super+1, Ctrl+Super+2, etc to switch desktops.
The reason seems to be that in Lubuntu 19.04, the Super key is used by LXQt differently than in previous Lubuntu versions.
... but in 19.04+, you’ll run into conflicts with lxqt-globalkeys using the key to open the menu, so either disable that, reconfigure that, or use something other than the Windows key here.
Source: https://discourse.lubuntu.me/t/how-to-snap-windows/247/4
If you're interested in window snapping, see Lubuntu 19.10: How to tile windows? The window tiling section is missing in lxqt-rc.xml.
DK Bose
  • 44,553
