Possible Duplicate:
How to get the native version of Spotify running?
I'm having trouble installing the Spotify Linux preview.
I'm kinda new to Ubuntu so I'm not sure if I did something wrong.
First, in the terminal, I ran this:
sudo gedit /etc/apt/sources.list
At the bottom, I added this:
deb http://repository.spotify.com stable non-free
# deb-src http://repository.spotify.com stable non-free
Then I ran this:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 4E9CFF4E
Next:
sudo apt-get update
It seemed to have gone well, as there were no error messages.
So next, I ran this:
sudo apt-get install spotify-client-qt
But when I did, I got this:
You might want to run 'apt-get -f install' to correct these:
spotify-client-qt : Depends: spotify-client but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Any ideas?
Edit
I'm using Ubuntu 11.10, and yes, I had the same error message the user had in that question:
Failed to fetch http://repository.spotify.com/dists/stable/Release Unable to find expected entry non-free/source/Sources in Meta-index file (malformed Release file?) Some index files failed to download, they have been ignored, or old ones used instead.
I added the # before the second line (which wasn't there) and I no longer received that error message.
Also, in reply to Bahaïka's comment, I ran that command (sudo apt-get install spotify-client) and I got the following:
spotify-client : Depends: libqt4-webkit (>= 4.5.0) but it is not going to be installed
Depends: libssl0.9.8 but it is not going to be installed
Recommends: libavcodec53 but it is not going to be installed or
libavcodec52 but it is not installable
Recommends: libavformat53 but it is not going to be installed or
libavformat52 but it is not installable
