I installed Ubuntu Server 18.04 LTS as a VM. Then I installed Unity desktop with --no-install-recommends as in below command:
sudo apt install --no-install-recommends ubuntu-unity-desktop
Now I want to remove desktop and return my good old terminal screen. I tried removing desktop with following command and reboot but nothing was changed after reboot.
sudo apt remove --purge ubuntu-unity-desktop
Is there a way to remove desktop totally?
NK_
  • 317
ubuntu-unity-desktop is a metapackage that has dependencies on other packages. Simply removing the metapackage doesn't remove the dependencies.
Run sudo apt autoremove --purge after you remove the metapackage, because the other dependencies weren't manually defined for installation but were instead included because ubuntu-unity-desktop needed them, you need to autoremove the 'now not needed' dependencies pulled in.
Thomas Ward
  • 78,878
For the record - with Ubuntu 18.04 slowly losing importance:
On Ubuntu 22.04 i had to remove the package "ubuntu-desktop-minimal" followed by "apt-get autoremove" to remove 158 desktop related packages.
neuhaus
  • 133
