I have a Lenovo 320 laptop with rtl8821ce wifi adapter. I was using Ubuntu 19.04 and the adapter worked after following these steps.
I upgraded to 19.10 and the wifi is not working now.
The output of lshw -C network is as follows
*-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 10
       serial: 8c:16:45:45:5c:35
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII
       resources: irq:16 ioport:4000(size=256) memory:a2104000-a2104fff memory:a2100000-a2103fff
  *-network UNCLAIMED
       description: Network controller
       product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:3000(size=256) memory:a2000000-a200ffff
  *-network
       physical id: 3
       logical name: bnep0
       serial: b0:fc:36:38:c0:d0
       capabilities: ethernet physical
       configuration: broadcast=yes ip=192.168.44.52 multicast=yes
This post had the same problem as me -including installing the driver from additional drivers- but following the accepted answer didn't work for me.
Is there anything else I can do?
$ lspci -nnk | grep 0280 -A3
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
    Subsystem: Lenovo RTL8821CE 802.11ac PCIe Wireless Network Adapter [17aa:c024]
    Kernel modules: wl, 8821ce, rtl8821ce
$ sudo dkms status
bcmwl, 6.30.223.271+bdcom, 5.3.0-22-generic, x86_64: installed
rtl8821ce, 5.2.5.2.1.30816.20190425, 5.3.0-22-generic, x86_64: installed
$ sudo modprobe rtl8821ce && dmesg | grep rtl
modprobe: ERROR: could not insert 'rtl8821ce': Device or resource busy
Zanna
  • 72,312
ahmed galal
  • 33
From the comments...
$ dkms status
Uninstall your current dkms driver (https://github.com/tomaspinho/rtl8821ce)...
cd rtl8821ce          # old source folder
sudo ./dkms-remove.sh # uninstall old dkms driver
dkms status
Now we make sure that duplicate 8821ce drivers have been removed...
sudo lspci -nnk | grep 0280 -A3 | grep modules
If you need a different driver, try this one... https://github.com/shubham151/rtl8821ce. (git clone https://github.com/shubham151/rtl8821ce.git). Don't follow the ReadMe there for how to install it, rather, follow the same procedure that you did before, so that you get the dkms install.
git clone https://github.com/shubham151/rtl8821ce.git # git clone new driver
cd rtl8821ce             # new source folder
chmod +x dkms-install.sh # make executable
chmod +x dkms-remove.sh  # make executable
sudo ./dkms-install.sh   # install new dkms driver
Update #1:
  • uninstalled bcmwl dkms module
  • uninstalled rtl8821ce dkms module
  • reinstalled rtl8821ce from .deb file
heynnema
  • 73,649
For recent ubuntu 20.04 LTS this should do the trick:
apt install rtl8821ce-dkms
Michael
  • 131
