Possible Duplicate:
Whats the simplest way to edit and add files to “/var/www”?
I can't seem to move folders or create new folders in the /var/www folder. This is the first time i have tried using Ubuntu and i can't seem to find a reason why i'm not able to move folders, i only have one account so should have all the priviliges.
Jon
  • 585
You need to set the proper filesystem privileges:
sudo chown <youruser>:www-data /var/www
sudo chmod 0775 /var/www
sudo chmod g+s /var/www
Replace <youruser> with your own username. No logout/login required.
Axel
  • 316
The /var/www/ folder is normally owned by root.
Try this
sudo chown root.www-data /var/www
sudo usermod -a -G www-data your-username
logoff then login, then try writing back to the /var/www folder
