10
I use ZFS to store my data, including configuration files, for my desktop PC, so it's important for my datasets to mount automatically on boot. I couldn't for the life of me figure out how to do this in Ubuntu 19.10.
At first, when I ran zfs list and zpool list, there was no output; it was empty. Then, after figuring out how to import my pools, they still wouldn't mount.
The correct way to do this is to make sure three unit files are enabled to start on boot:
  • zfs.target, which is the overarching target for all of ZFS
  • zfs-import.service, which imports zpools at boot
  • zfs-mount.service, which mounts all datasets at boot
These units have dependencies set up correctly, so you can simply run:
systemctl enable zfs.target zfs-import.service zfs-mount.service
to ensure they are all turned on. After this, reboot to test; your ZFS datasets should show up.
I have found that zfs-zed.service which updates zpool cache and zfs-list cache to no longer be running after a systemctl suspend and require manual restart, if I forget that the caches don't get updated for any later changes for next reboot. I'll improve this with details shortly to replicate and try a clean install on the weekend and or move this to the to the proper place. Openzfs 2.1.5 with compatibility set to openzfs-2.1-linux. Ubuntu 22.04 and proxmox hacked with zsys sharing boot and root pools.
Update for 22.04 LTS:
Instructions exist in the zfs-mount-generator(8) manual page, but I had to make a few changes. Here's what worked for me:
# enable tracking for the pool
mkdir /etc/zfs/zfs-list.cache
touch /etc/zfs/zfs-list.cache/main
enable the tracking ZEDLET
systemctl enable zfs-zed.service systemctl restart zfs-zed.service
trigger cache refresh
zfs set relatime=off main/secure zfs inherit relatime main/secure
re-run systemd generators and reboot
systemctl daemon-reload reboot
Adam Monsen
  • 2,161
