I have a Acer Travelmate 8572G which ran with Windows 7 before.
From time to time it randomly happened, that the screen froze and I had to shut down using the power button.
Now I switched to Ubuntu and it seems, it shows the same behaviour. As I am new to Ubuntu, any help / hint is highly appreciated.
What I did so far:
- Windows: A friend who is a system administrator had a look at it: he could not find anything. Performance, especially boot time was (and is) great.
- Ubuntu: I searched, but could not find anything. According to this question, I tried
dmesg; its output is below. - Ubuntu: From here in combination with my
dmesgoutput I guess that I have an ACPI error? Please see 22.824497 seconds into the dmesg output below.
Please let me know, if you need anything else. I marked the the part where I think the error messages occur.
Output from dmesg
[ 3.220523] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.323939] intel ips 0000:00:1f.6: CPU TDP doesn't match expected value (found 25, expected 29)
[ 3.324993] intel ips 0000:00:1f.6: failed to get i915 symbols, graphics turbo disabled until i915 loads
[ 3.327444] intel ips 0000:00:1f.6: IPS driver initialized, MCP temp limit 90
[ 3.407857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.453189] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.609551] media: Linux media interface: v0.10
[ 3.690379] wl: loading out-of-tree module taints kernel.
[ 3.690385] wl: module license 'MIXED/Proprietary' taints kernel.
[ 3.690386] Disabling lock debugging due to kernel taint
[ 3.695116] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 3.695824] videodev: Linux video capture interface: v2.00
[ 3.705139] cryptd: max_cpu_qlen set to 1000
[ 3.760550] SSE version of gcm_enc/dec engaged.
[ 3.771100] pci 0000:00:00.0: Intel HD Graphics Chipset
[ 3.771129] pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 3.771581] pci 0000:00:00.0: detected 131072K stolen memory
[ 3.771639] checking generic (d0000000 300000) vs hw (d0000000 10000000)
[ 3.771640] fb: switching to inteldrmfb from VESA VGA
[ 3.771695] Console: switching to colour dummy device 80x25
[ 3.771972] [drm] Replacing VGA console driver
[ 3.774977] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.774979] [drm] Driver supports precise vblank timestamp query.
[ 3.776407] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 3.816059] [drm] RC6 disabled, disabling runtime PM support
[ 3.825911] wlan0: Broadcom BCM4357 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 3.852606] [drm] Initialized i915 1.6.0 20180514 for 0000:00:02.0 on minor 0
[ 3.852933] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 3.853355] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 3.853708] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input13
[ 3.855847] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.855988] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:02/input/input14
[ 3.859285] uvcvideo: Found UVC 1.00 device 1.3M WebCam (04f2:b1d8)
[ 3.872794] fbcon: inteldrmfb (fb0) is primary device
[ 3.872913] Console: switching to colour frame buffer device 170x48
[ 3.872970] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 3.878900] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 3.878949] acer_wmi: Function bitmap for Communication Button: 0x801
[ 3.879321] input: Acer WMI hotkeys as /devices/virtual/input/input15
[ 3.895243] MXM: GUID detected in BIOS
[ 3.896572] uvcvideo 1-1.1:1.0: Entity type for entity Extension 4 was not initialized!
[ 3.896575] uvcvideo 1-1.1:1.0: Entity type for entity Processing 3 was not initialized!
[ 3.896577] uvcvideo 1-1.1:1.0: Entity type for entity Camera 1 was not initialized!
[ 3.896680] input: 1.3M WebCam: 1.3M WebCam as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input16
[ 3.897613] usbcore: registered new interface driver uvcvideo
[ 3.897615] USB Video Class driver (1.1.1)
[ 3.898009] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180531/nsarguments-66)
[ 3.898073] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 3.898131] ACPI Warning: \_SB.PCI0.P0P2.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180531/nsarguments-66)
[ 3.898166] ACPI: \_SB_.PCI0.P0P2.PEGP: failed to evaluate _DSM
[ 3.898174] VGA switcheroo: detected DSM switching method \_SB_.PCI0.GFX0 handle
[ 3.898227] nouveau 0000:01:00.0: enabling device (0004 -> 0007)
[ 3.909950] nouveau 0000:01:00.0: NVIDIA GT216 (0a5480a2)
[ 3.950155] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.001666] snd_hda_codec_conexant hdaudioC0D0: CX20585: BIOS auto-probing.
[ 4.002169] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX20585: line_outs=1 (0x1f/0x0/0x0/0x0/0x0) type:speaker
[ 4.002172] snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.002174] snd_hda_codec_conexant hdaudioC0D0: hp_outs=1 (0x19/0x0/0x0/0x0/0x0)
[ 4.002176] snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
[ 4.002177] snd_hda_codec_conexant hdaudioC0D0: inputs:
[ 4.002180] snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x23
[ 4.002182] snd_hda_codec_conexant hdaudioC0D0: Mic=0x1b
[ 4.003293] snd_hda_codec_conexant hdaudioC0D0: Enable sync_write for stable communication
[ 4.014134] wl 0000:09:00.0 wlp9s0: renamed from wlan0
[ 4.027934] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 4.028042] input: HDA Intel MID Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 4.028675] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 4.441535] acer_wmi: Set Device Status failed: 0xe1 - 0x0
[ 4.829508] usb 1-1.2: new full-speed USB device number 5 using ehci-pci
[ 4.858452] nouveau 0000:01:00.0: bios: version 70.16.57.00.07
[ 4.903948] acer_wmi: Set Device Status failed: 0xe1 - 0x0
[ 4.904948] acer_wmi: Set Device Status failed: 0xe1 - 0x0
[ 4.939950] usb 1-1.2: New USB device found, idVendor=0489, idProduct=e011, bcdDevice= 8.61
[ 4.939954] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.939956] usb 1-1.2: Product: Acer Module
[ 4.939957] usb 1-1.2: Manufacturer: Broadcom Corp
[ 4.939959] usb 1-1.2: SerialNumber: C44619C300D0
[ 4.980230] Bluetooth: Core ver 2.22
[ 4.980260] NET: Registered protocol family 31
[ 4.980261] Bluetooth: HCI device and connection manager initialized
[ 4.980267] Bluetooth: HCI socket layer initialized
[ 4.980270] Bluetooth: L2CAP socket layer initialized
[ 4.980278] Bluetooth: SCO socket layer initialized
[ 4.993249] usbcore: registered new interface driver btusb
[ 5.228962] nouveau 0000:01:00.0: fb: 1024 MiB DDR3
[ 5.312519] vga_switcheroo: enabled
[ 5.312773] [TTM] Zone kernel: Available graphics memory: 1852308 kiB
[ 5.312776] [TTM] Initializing pool allocator
[ 5.312785] [TTM] Initializing DMA pool allocator
[ 5.312829] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 5.312831] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 5.312838] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 5.312841] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 5.312845] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000323 00010034
[ 5.312848] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011300 00000000
[ 5.312851] nouveau 0000:01:00.0: DRM: DCB outp 02: 08022382 00020010
[ 5.312854] nouveau 0000:01:00.0: DRM: DCB conn 00: 00000040
[ 5.312857] nouveau 0000:01:00.0: DRM: DCB conn 01: 00000100
[ 5.312859] nouveau 0000:01:00.0: DRM: DCB conn 02: 00001231
[ 5.314331] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.314332] [drm] Driver supports precise vblank timestamp query.
[ 5.316642] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 5.329342] [drm] Cannot find any crtc or sizes
[ 5.329389] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[ 5.643527] audit: type=1400 audit(1572891771.341:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=744 comm="apparmor_parser"
[ 5.644378] audit: type=1400 audit(1572891771.345:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=743 comm="apparmor_parser"
[ 5.644382] audit: type=1400 audit(1572891771.345:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=743 comm="apparmor_parser"
[ 5.644385] audit: type=1400 audit(1572891771.345:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=743 comm="apparmor_parser"
[ 5.646279] audit: type=1400 audit(1572891771.345:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=745 comm="apparmor_parser"
[ 5.649118] audit: type=1400 audit(1572891771.349:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=747 comm="apparmor_parser"
[ 5.650343] audit: type=1400 audit(1572891771.349:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=740 comm="apparmor_parser"
[ 5.650349] audit: type=1400 audit(1572891771.349:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=740 comm="apparmor_parser"
[ 5.650352] audit: type=1400 audit(1572891771.349:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=740 comm="apparmor_parser"
[ 5.650355] audit: type=1400 audit(1572891771.349:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=740 comm="apparmor_parser"
[ 6.049580] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.049582] Bluetooth: BNEP filters: protocol multicast
[ 6.049588] Bluetooth: BNEP socket layer initialized
[ 6.784332] acer_wmi: Set Device Status failed: 0xe1 - 0x0
[ 6.868584] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 7.649860] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 7.650374] tg3 0000:02:00.0 enp2s0: Link is down
[ 7.655387] IPv6: ADDRCONF(NETDEV_UP): wlp9s0: link is not ready
[ 7.773579] IPv6: ADDRCONF(NETDEV_UP): wlp9s0: link is not ready
[ 8.587261] IPv6: ADDRCONF(NETDEV_CHANGE): wlp9s0: link becomes ready
[ 8.644167] intel ips 0000:00:1f.6: i915 driver attached, reenabling gpu turbo
[ 15.339495] [drm] Cannot find any crtc or sizes
[ 21.429677] random: crng init done
[ 21.429683] random: 7 urandom warning(s) missed due to ratelimiting
[ 22.044286] systemd-journald[284]: File /var/log/journal/b1646eb850b94782bceafaf807262c01/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 22.824086] calling mux switch 16
[ 22.824269] mux mutex set switched 0
[ 22.824270] calling mux switch 16
[ 22.824372] mux switched 0
# I guess, the error occurs here for the first time #
[ 22.824497] ACPI Error: Needed [Buffer/String/Package], found [Integer] 00000000d30f9b04 (20180531/exresop-560)
[ 22.824508] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 22.824519]
Initialized Local Variables for Method [_DSM]:
[ 22.824520] Local0: 000000000780b2c6 <Obj> Integer 0000000000000002
[ 22.824531] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 22.824532] Arg0: 0000000083736f51 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 22.824545] Arg1: 00000000c1efc734 <Obj> Integer 0000000000000102
[ 22.824551] Arg2: 00000000c6f9db73 <Obj> Integer 0000000000000002
[ 22.824557] Arg3: 00000000d30f9b04 <Obj> Integer 0000000000000011
[ 22.824593] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 22.824630] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 22.824633] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 22.824868] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000083736f51 (20180531/exresop-560)
[ 22.824879] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 22.824921]
[ 22.824923] Local0: 0000000058fe9de2 <Obj> Integer 0000000000000003
[ 22.824939] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 22.824943] Arg0: 00000000d30f9b04 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 22.824970] Arg1: 00000000c6f9db73 <Obj> Integer 0000000000000102
[ 22.824992] Arg2: 00000000c1efc734 <Obj> Integer 0000000000000003
[ 22.825005] Arg3: 0000000083736f51 <Obj> Integer 0000000000000002
[ 22.825036] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 22.825100] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 22.825105] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 22.826589] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000057f04209 (20180531/exresop-560)
[ 22.826602] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 22.826616]
[ 22.826618] Local0: 00000000e974a610 <Obj> Integer 0000000000000003
[ 22.826628] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 22.826629] Arg0: 0000000012f5820b <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 22.826646] Arg1: 000000000f466259 <Obj> Integer 0000000000000102
[ 22.826653] Arg2: 0000000005330fde <Obj> Integer 0000000000000003
[ 22.826661] Arg3: 0000000057f04209 <Obj> Integer 0000000000000001
[ 22.826673] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 22.826697] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 22.826699] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 26.142654] Bluetooth: RFCOMM TTY layer initialized
[ 26.142668] Bluetooth: RFCOMM socket layer initialized
[ 26.142678] Bluetooth: RFCOMM ver 1.11
[ 27.863669] rfkill: input handler disabled
[ 33.200097] calling mux switch 16
[ 33.200343] mux mutex set switched 0
[ 33.200345] calling mux switch 16
[ 33.200509] mux switched 0
[ 33.200705] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000059808404 (20180531/exresop-560)
[ 33.200720] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 33.200736]
[ 33.200738] Local0: 000000006ceea97c <Obj> Integer 0000000000000002
[ 33.200752] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 33.200753] Arg0: 0000000085ac64b1 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 33.200773] Arg1: 000000008e6a5056 <Obj> Integer 0000000000000102
[ 33.200783] Arg2: 000000003ee2fd50 <Obj> Integer 0000000000000002
[ 33.200791] Arg3: 0000000059808404 <Obj> Integer 0000000000000011
[ 33.200808] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 33.200835] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 33.200838] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 33.201033] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000085ac64b1 (20180531/exresop-560)
[ 33.201045] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 33.201059]
[ 33.201061] Local0: 00000000c68c3a43 <Obj> Integer 0000000000000003
[ 33.201073] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 33.201074] Arg0: 0000000059808404 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 33.201094] Arg1: 000000003ee2fd50 <Obj> Integer 0000000000000102
[ 33.201103] Arg2: 000000008e6a5056 <Obj> Integer 0000000000000003
[ 33.201111] Arg3: 0000000085ac64b1 <Obj> Integer 0000000000000002
[ 33.201128] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 33.201152] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 33.201155] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 33.201429] ACPI Error: Needed [Buffer/String/Package], found [Integer] 0000000083736f51 (20180531/exresop-560)
[ 33.201442] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 33.201455]
[ 33.201457] Local0: 000000003c29275f <Obj> Integer 0000000000000003
[ 33.201467] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 33.201469] Arg0: 00000000c1efc734 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 33.201485] Arg1: 00000000c6f9db73 <Obj> Integer 0000000000000102
[ 33.201492] Arg2: 00000000d30f9b04 <Obj> Integer 0000000000000003
[ 33.201500] Arg3: 0000000083736f51 <Obj> Integer 0000000000000001
[ 33.201513] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 33.201536] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 33.201538] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 41.224500] calling mux switch 16
[ 41.224709] mux mutex set switched 0
[ 41.224711] calling mux switch 16
[ 41.224833] mux switched 0
[ 41.224981] ACPI Error: Needed [Buffer/String/Package], found [Integer] 000000006ceea97c (20180531/exresop-560)
[ 41.224995] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 41.225008]
[ 41.225010] Local0: 0000000006bf947e <Obj> Integer 0000000000000002
[ 41.225021] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 41.225022] Arg0: 000000003ee2fd50 <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 41.225039] Arg1: 000000008e6a5056 <Obj> Integer 0000000000000102
[ 41.225046] Arg2: 0000000085ac64b1 <Obj> Integer 0000000000000002
[ 41.225053] Arg3: 000000006ceea97c <Obj> Integer 0000000000000011
[ 41.225066] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 41.225088] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 41.225091] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
[ 41.225297] ACPI Error: Needed [Buffer/String/Package], found [Integer] 000000003ee2fd50 (20180531/exresop-560)
[ 41.225306] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Index] (20180531/dswexec-427)
[ 41.225317]
[ 41.225318] Local0: 0000000059808404 <Obj> Integer 0000000000000003
[ 41.225328] Initialized Arguments for Method [_DSM]: (4 arguments defined for method invocation)
[ 41.225330] Arg0: 000000006ceea97c <Obj> Buffer(16) A0 A0 95 9D 60 00 48 4D
[ 41.225346] Arg1: 0000000085ac64b1 <Obj> Integer 0000000000000102
[ 41.225353] Arg2: 000000008e6a5056 <Obj> Integer 0000000000000003
[ 41.225360] Arg3: 000000003ee2fd50 <Obj> Integer 0000000000000002
[ 41.225372] ACPI Error: Method parse/execution failed \_SB.PCI0.GFX0._DSM, AE_AML_OPERAND_TYPE (20180531/psparse-516)
[ 41.225392] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x3003)
[ 41.225394] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM
