And if so, are there any tutorials?
Total noobie here; I know nothing about scripting, bash, foo.
All I know is 'sudo' and how to edit a file in with nano without making a total hash of things.
Will this excerpt from this tutorial Can you install Ubuntu on the Raspberry Pi 4 still work?
Solid State Drive (SSD) Configuration (Optional)
USB booting has not been added into the Raspberry Pi 4 firmware yet but is being worked on right now. In the mean time you can use your micro SD card as a bootloader and still boot the whole operating system (rootfs) from the solid state drive giving you the full USB 3.0 speed increases system wide. Once the Pi USB booting is officially released you should be able to boot directly from the device without any makeshift bootloader SD card necessary.
First create a fully imaged and booting micro SD card following the earlier steps in the tutorial. After you have created the micro SD installation you should now image your SSD / USB drive with the same Ubuntu image you used to create the SD card.
Now navigate to the “boot” partition on the newly created SSD / USB drive and remove everything in there just like we did with the SD card earlier. Now copy the “boot” folder from the micro SD card to the solid state drive. This is necessary because even though the files in “boot” are read off our micro SD card initially some firmware files in the later load stages are read off the mounted drive and if the necessary firmware files are missing the system won’t boot.
Now that you’ve created the SSD / USB drive partitions and copied the “boot” partition from the SD card to your new drive we need to update your SD card’s cmdline.txt to point to the SSD / USB drive’s partition.
dwc_otg.fiq_fix_enable=2 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4rootwait rootflags=noload net.ifnames=0
The key part we need to change here is the
root=/dev/mmcblk0p2section.mmcblk0p2is a hardware identifier for micro SD storage. We need to change this to the device your storage is detected as.If you are using a USB to solid state drive adapter it’s very likely your drive will be addressed as /dev/sda2. Therefore we will change the
root=/dev/mmcblk0p2toroot=/dev/sda2root=/dev/sda2The final line will be:
dwc_otg.fiq_fix_enable=2 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/sda2 rootfstype=ext4rootwait rootflags=noload net.ifnames=0
Plug both the micro SD and the solid state drive into the Pi and boot it up.
Remember: the first boot can take 2-3 minutes for first startup so give it some time before assuming it didn’t work.
