There is no problem in other OS. Default expected behavior for standart PC - is that you:
  • Set up NumLock initial status in the bios
  • It remains same in bootloader
  • It remains same at login screen
  • It remains same in desktop session, until you intentionally change it.
So here seems to be a problem, in some "malicious" code, that forcefully disables it, during boot. Question is: What exactly disables it? What binary? Or what source file? Can I remove it, at least locally, on my machine, in order to stop Ubuntu from changing NumLock state at boot?
Or maybe that's a tweak, like Troubleshooting features > [V] Force disable num lock at boot, that was occasionally enabled by default?
I've concluded some searches, what I've found is that:
  • Official information is outdated. There is no such menu in Ubuntu Settings as per 18.04 LTS.
  • A couple of threads, here and there, are also not answering where does the illness seats.
  • Installing and using numlockx is a stub. Why do we need disable (initially enabled) NumLock, and then use additional software to re-enable it? Such an advice really sounds like somthing "conceptually wrong".
Can you help to find out, where is the disease source, and how to fight it?
xakepp35
  • 325
Ubuntu 20:
All the same reasoning applies but the specific key/values have changed
org.gnome.desktop.peripherals.keyboard remember-numlock-state true
org.gnome.desktop.peripherals.keyboard numlock-state false
Kulfy
  • 18,154
For Ubuntu Gnome 18.04+
When you are at the login screen the user ID active is gdm (Gnome Desktop Manager). To change that profile login with your own user ID and use:
sudo -i
xhost +SI:localuser:gdm
su gdm -s /bin/bash
gsettings set org.gnome.settings-daemon.peripherals.keyboard numlock-state 'on'
gsettings set org.gnome.desktop.peripherals.touchpad tap-to-click true
For a plethora of even more options:
For Ubuntu Unity 16.04+
Install the the program numlockx:
$ sudo apt update && sudo apt install numlockx
$ numlockx -h NumLockX 1.2 (C) 2000-2001 Lubos Lunak <l.lunak@kde.org> (C) 2001 Oswald Buddenhagen <ossi@kde.org>
Usage: numlockx [on|off|toggle|status] on - turns NumLock on in X ( default ) off - turns NumLock off in X toggle - toggles the NumLock on and off in X status - gets the NumLock status
Next step is to get it running during login screen:
$ locate 50-unity-greeter.conf
/usr/share/lightdm/lightdm.conf.d/50-unity-greeter.conf
$ sudo -H gedit /usr/share/lightdm/lightdm.conf.d/50-unity-greeter.conf
At bottom of file add:
greeter-setup-script=/usr/bin/numlockx on
Save file and login again.
Catchall when everything fails
Install numlockx as show above. Then
$ sudo -H gedit /etc/rc.local
Save file and reboot.
I actually wanted to disable numlock but this may well also force the enable situation as well.
I installed numlockx by running:
and set the default status in /etc/default/numlockx:
# Configuration file for numlockx
State of numlog on start of X session
Accepts following options:
auto - turns numlock on unless ran on laptop
on - turns numlock on
off - turns numlock off
keep - does not change numlock state
toggle - toggles numlock state
NUMLOCK=off
A sledgehammer approach but worked.
