I'm trying to accomplish a simple task using the excellent post here: I would like to remove all files from a folder except those listed in a .txt file contained in the folder. The syntax works fine, but for some reason all files are removed - basically the script is saying that there are no correspondences between the filenames in the folder and those in the .txt file - but I can see that there are!
I thought maybe there might be some invisible white space after my file names that I cannot see (in the folder or the .txt file). But I don't think so...Is there another solution that I am not thinking of?
MeC
  • 111
It seems that your a.txt file contains hidden characters due to possibly being created or edited on other OS's like Windows.
You need to sanitize the file first in order to use it without syntax errors.
The easiest way is to use a tool called dos2unix. Please follow these steps to do so:
Firstly: Install dos2unix by opening a terminal and running the following command:
sudo apt install dos2unix
Secondly: Back up your a.txt file.
Thirdly: Use dos2unix on your file by running the following command in the terminal from within the directory containing your a.txt file:
dos2unix a.txt
Finally: Test your file. It should be fine now.
Raffa
  • 34,963
The script you are referring to will give false positives. for will expand filenames literally, this means special characters will be preserved and using it as a pattern will break the matching.
Example:
#!/bin/bash
# the script is adapted and slightly shortened.
shopt -s nullglob
for i in a* b*; do
   grep -Fx -e "$i" exclude.txt
done
Output:
$ ls
a   'a'$'\n''b'   b   exclude.txt
$ cat exclude.txt
a
b
$ script.sh
a
a
b
b
A better approach would be to preserve the shell-escape.
#!/bin/bash
shopt -s extglob
eval "list=( \
    $(ls --quoting-style=shell-escape !(exclude.txt) | \
        grep -vFx -f exclude.txt))"
for i in "${list[@]}"; do ls "$i"; done
Example:
$ cat exclude.txt
'a'$'\n''b'
$ script.sh
a
b
$ cat exclude.txt
a
b
$ script.sh
'a'$'\n''b'
