I have been playing around with it for a little while but am pretty stuck with creating a service to run a script. The script I am trying to run is as follows.
#!/bin/sh
while true
do
sudo bbb-record --rebuildall
sleep 300
done
I tried creating a daemon for this to run like:
[Unit]
Description=bbb-rebuild
[Service]
ExecStart=/home/sysadmin/rebuild
Restart=always
[Install]
WantedBy=multi-user.target
exit=0
I get the error message
==== AUTHENTICATION COMPLETE ===
Failed to start rebuild.service: Unit rebuild.service is not loaded properly: Invalid argument.
See system logs and 'systemctl status rebuild.service' for details.
after checking status
Apr 22 16:46:55 bbb2 systemd[1]: rebuild.service: Unit entered failed state.
Apr 22 16:46:55 bbb2 systemd[1]: rebuild.service: Failed with result 'exit-code'.
Apr 22 16:46:55 bbb2 systemd[1]: rebuild.service: Service hold-off time over, scheduling restart.
Apr 22 16:46:55 bbb2 systemd[1]: Stopped bbb-rebuild.
Apr 22 16:46:55 bbb2 systemd[1]: rebuild.service: Start request repeated too quickly.
Apr 22 16:46:55 bbb2 systemd[1]: Failed to start bbb-rebuild.
Apr 22 16:46:55 bbb2 systemd[1]: rebuild.service: Failed with result 'start-limit-hit'.
Apr 22 16:47:22 bbb2 systemd[1]: [/etc/systemd/system/rebuild.service:12] Missing '='.
Kulfy
  • 18,154
You should better use systemd-timers to achieve this.
Create a timer named like your systemd service rebuild.timer
# nano /etc/systemd/system/rebuild.timer
[Unit]
Description=Start script every hour
[Timer]
OnCalendar=hourly
[Install]
WantedBy=timers.target
Edit your script to the following
#!/bin/sh
Ensure your script is runable chmod +x /home/sysadmin/rebuild
Edit your systemd service to remove restart=always and exit 0
[Unit]
[Service]
[Install]
Then simply enable your systemd-timer with systemctl enable rebuild.timer.
Then check the timer is enabled with systemctl status rebuild.timer.
Fractalyse
  • 439
