I have been trying to install Latte Dock on Ubuntu with KDE Plasma, I keep getting errors with unmet dependencies. I tried removing the old packages but that removes the entirety of KDE Plasma. Any help?
Reading package lists... Done
Building dependency tree
 latte-dock : Depends: libkf5declarative5 (>= 5.45.0) but 5.44.0-0ubuntu3 is to be installed
              Depends: libkf5waylandclient5 (>= 4:5.47.0) but 4:5.44.0-0ubuntu1 is to be installed
RinW
  • 121
I fixed this by adding the KUbuntu Backports PPA and doing an update. This updated the packages which were outdated.
sudo add-apt-repository ppa:kubuntu-ppa/backports
This updated all the packages (many) and the installed Latte through the KDE Store.
Kulfy
  • 18,154
RinW
  • 121
You should try to fix all broken packages you have with:
apt install -f
Eliah Kagan
  • 119,640
