Ivo's (https://askubuntu.com/users/632873/ivo-bl%c3%b6chliger) solution at Lenovo ThinkPad X1 Yoga OLED Brightness for a Yoga laptop also works for the Dell XPS 15-9570. The only thing I had to change was to subtract/add 6000 instead of the 71 in the script. That gives me a 20 step change, i.e. up/down by 5% for every key press.
This is what the modified solution looks like for the XPS 15, using similar three files. The first one is /etc/acpi/events/xps-brightness-up:
event=video/brightnessup BRTUP 00000086
action=/etc/acpi/xps-brightness.sh up
nuber two is /etc/acpi/events/xps-brightness-down:
event=video/brightnessdown BRTDN 00000087
action=/etc/acpi/xps-brightness.sh down
and then the main script /etc/acpi/xps-brightness.sh:
#!/bin/sh
# Where the backlight brightness is stored
BR_DIR="/sys/devices/pci0000:00/0000:00:02.0/drm/card0/card0-eDP-1/intel_backlight/"
test -d "$BR_DIR" || exit 0
MIN=0
MAX=$(cat "$BR_DIR/max_brightness")
VAL=$(cat "$BR_DIR/brightness")
if [ "$1" = down ]; then
VAL=$((VAL-6000))
else
VAL=$((VAL+6000))
fi
if [ "$VAL" -lt $MIN ]; then
VAL=$MIN
elif [ "$VAL" -gt $MAX ]; then
VAL=$MAX
fi
PERCENT=`echo "$VAL / $MAX" | bc -l`
export XAUTHORITY=/home/user/.Xauthority # CHANGE "user" TO YOUR USER
export DISPLAY=:0.0
echo "xrandr --output eDP-1 --brightness $PERCENT" > /tmp/xps-brightness.log
echo $VAL > "$BR_DIR/brightness"
Don't forget to do a chmod a+x /etc/acpi/xps-brightness.sh and restart acpi by typing
sudo service acpid reload
I hope, this helps ;-)
