28
Is the difference between sudo cmd and gksu cmd, the same as the difference
between starting a shell with sudo -i and sudo -s?
... or put another way,
Is sudo cmd the same as sudo -i cmd
and gksu cmd the same as sudo -s cmd?
EDIT: Based on what I read on an Ubuntu Documentation Page where it says:
You should never use normal sudo to start graphical applications as root.
You should use gksudo (kdesudo on Kubuntu) to run such programs. gksudo sets
HOME=~root, and copies .Xauthority to a tmp directory. This prevents files
in your home directory becoming owned by root.
(AFAICT, this is all that's special about the environment of the started
 process with gksudo vs. sudo).
The "AFAICT" doen't really give me full confidence that there is nothing more to it.
(..a belated UPDATE: I tested his commemnt today (2 months later) about:
"This prevents files in your home directory becoming owned by root."
All files I created via sudo/gksu were all owned by "root", and the group was "root".)
I've read parts of the info sudo and noticed the -i and -s seem to be doing the same thing as the AFAICT environment issue...
but I hit overload.. so I've asked my question here.
PS.. My question is not about sudo vs gksu
.. It is more about: Is gksu the same as sudo -s
.. and if not, how do they differ?
Peter.O
  • 25,251
gksu is basically a graphical frontend for sudo that allows graphical command to be run without the need to run an X terminal emulator and using su directly. It's effectively just a GTK+ skin for the superuser commands.
So if you wanted to run a GUI based program as root, you would invoke it with gksu cmd, rather than sudo cmd, which is used for invoking console programs as root.
11
sudo -i resets the login environment to the target user (root, in this case). Mainly, it is that the HOME environment variable is changed, which means the target user's ~/.bashrc is loaded.
gksu is, therefore, like sudo -i in that is switches $HOME to the root user.
Kees Cook
  • 17,823
This isn't really an answer, but it may be of some interest...
I'm starting to get an idea of what goes on with these su commands,
but I'm not quite there yet... I do use gksu... This is more a journey of understanding for me... and I wan't to understand if gksu is valid for konsole or kate, or must I use the KDE variant kdesu..
Here are some results of some tests I've just tried.
From user fred's terminal, launch gnome-terminal
su style   resulting            custom   (ls)   new file
command    prompt               prompt   home   ownership
sudo      .root@DT:~#           fred's   fred   root
gksu       root@DT:/home/fred#  root's   fred   root
sudo -i    root@DT:~#           root's   root   root
sudo -s   .root@DT:~#           fred's   fred   root
These results don't agree with the Ubuntu Documentation Page, where it says:
UPDATE: The XAUTHORITY env variables for the sudo and gksu invoked Terminals are different (as mentioned on the Ubuntu Documentation Page) ..
sudo    #### XAUTHORITY=/var/run/gdm/auth-for-fred-RsngLK/database
sudo -i #### XAUTHORITY=/var/run/gdm/auth-for-fred-RsngLK/database
sudo -s #### XAUTHORITY=/var/run/gdm/auth-for-fred-RsngLK/database
gksu    #### XAUTHORITY=/tmp/libgksu-xR2OGn/.Xauthority
This shows that gksu is definitely not the same as the sudo -s command I referred to in the question ... and therefore anwers my otiginal question (in some still obscure way) ... and Chris's answer certainly got me thinking hard on this one! ... I need a coffee!!
Peter.O
  • 25,251
sudo is for command line apps, gksu/gksudo for graphical ones
karthick87
  • 84,513
