I have Ubuntu 18.04.3 installed on a USB stick. Starts on UEFI Laptop. The question is how to boot the computer from the BIOS on such a pendrive? There is a possibility?
Try changing the boot order from your HDD or SSD to Pendrive by pressing f9 before something loads up.
Insert ubuntu installed pen-drive > Press Power button > start pressing f9(Function key) > move up/down by pressing ↑/↓ choose pendive > press enter.
Try to boot up once with changing boot order if it goes correctly you can also change boot order permanently in BIOS under boot option.
If this doesn't work kindly let me know.
- 11
- 3
There are basically three different configurations of Ubuntu systems in USB drives.
- Live-only system for testing, installing, repairing
- Persistent live system for a portable system, where you can install programs and save data
- Installed system, installed like into an internal drive, but into a USB drive
Live-only system
- Easiest to create, simply clone from the iso file to the USB drive
- Good enough in most cases
- Boots both in UEFI mode and BIOS mode
- Fairly easy to create, when you use a suitable tool
- Very good portability between computers
- You can install application programs, tweak the system and save files
- You cannot upgrade the linux kernel and its device drivers
- Sensitive to corruption (you need frequent backups)
Installed system
An installed system, installed like into an internal drive, but into a USB drive.
- Fairly easy to create, if you want to run in either UEFI or BIOS mode
- Possible but more difficult to make it boot both in UEFI and BIOS mode
- Fairly good portability between computers
- You can install and tweak 'everything' just like with a system installed into an internal drive (only limited by the size of the drive)
- Fairly robust to corruption, but a USB pendrive's hardware is sensitive to corruption (you need frequent backups)
Details and links
I think that you want an installed system, that can boot both in UEFI and BIOS mode, and in that case the following links may be helpful,
https://help.ubuntu.com/community/Installation/UEFI-and-BIOS
How do I install Ubuntu to a USB key? (without using Startup Disk Creator)
Installed system booting via mkusb's boot system by C.S.Cameron
- 47,684
