i was tryin to connect my ubuntu toshiba satalite L650 laptop with my desktop via a network cable so that i can share things and remotely control the desktop from the laptop, i googled the problem out and found a guide page , i followed all the steps , i installed samba, i had the two computer have the same workgroup name , i had everything correct, but i still dont see connection estbalished between the two computers, (neither one is visible to the other) what is missing ? thanx in advance.
twister_void
  • 5,934
VeXe
  • 423
This link will help u go through these references :
What is the easiest method to share files between Windows and Ubuntu?
How to setup a LAN between Ubuntu and Windows
Sharing Internet
twister_void
  • 5,934
You need a crossover cable to connect 2 machines directly (without a router/switch/hub).
Crossover cables are usually marked with a label and/or have red connectors, but it is not a standard. The best way to determine is to compare the wiring colours at the connectors. If they seem to match it is a straight through cable.
Crossover cable
Crossover cable
Alternatively you can use a switch/hub/router and another cable to connect the machines into a network. In this case you'll need 2 normal cables and a eg. switch:
[ Machine 1 ]-----[ Switch ]-----[ Machine 2 ]
lgarzo
  • 20,492
