I have a month-old Dell laptop running Ubuntu. When I have it on my desk, I normally plug a stereo receiver into the audio jack, and play all sound through the receiver. But recently, I've started getting a loud hum with this setup.
The hum starts several seconds after plugging in the audio cable. The hum only appears when no application is playing any sound. When the computer outputs any kind of sound (from a music player, or audio feedback due to clicking something) the hum stops, but then the hum starts again several seconds after the sound stops.
There is no hum when I plug headphones into the audio jack - it only happens with the receiver. There is no hum when I connect other audio sources (like my phone) to the receiver.
Is there anything I can do to help narrow this down?
System info:
  • Dell Precision 7530
  • Ubuntu (installed at the factory) running kernel version 4.15.0-1057-oem
  • Mate desktop, version 1.20.1-2ubuntu1
  • Realtek ALC289 audio chip
Mike Baranczak
  • 195
I ended up adding pavucontrol to my startup items. Only drawback is that I still get short hums, during bootup.
I'm on 24.04, and the problem occurs when connecting my M-AUDIO active monitors. No difference if on battery or connected to a power source.
As proposed somewhere in the comments above, the root cause could be power saving: Annoying click/popping sound on Ubuntu 20.04 (adding this here for better visibility - it did not help in my case).
benzkji
  • 193
