I tried to change my keyboard layout to german:
loadkeys de
But this is only temporary, if I reboot, then it it set back to english again... I tried to make it permanent:
localectl set-keymap de
but I get, "localectl : command not found"
Black
  • 844
you could try to manually modify sudo nano /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="de"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
AlexOnLinux
  • 1,012
  • 20
You can simply put it into your bashrc, if it located in your default directory it will be:
echo loadkeys de >> ~/.bashrc
If it does not work you can try using rc.local which run just before the login screen, be careful I never tried this but it should be fine:
create or open the file rc.local with your favorite editor like nano /etc/rc.local
Then paste this text
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
loadkeys de
exit 0
then give it the proper right chmod +x /etc/rc.local
Saxtheowl
  • 2,394
  • 22
