11
This happens only in Skype on Ubuntu 18.04. I have used Skype on other platforms (Ubuntu and others) and this does not happen. I use ALT+SHIFT to switch keyboard layout to another language. When I use Skype on Ubuntu 18.04 and press ALT+SHIFT the language is changed but also the focus is moved to the application menu (as if I had pressed ALT only).
Any help is welcome!
I guess the way you have set-up your ALT+SHIFT shortcut is via gnome-tweak-tool?
If that's the case - I have the same issue with slack, after some digging found out that there is another way to change the keyboard layout w/o using gnome-tweak-tool which wont cause this side effect of losing the focus.
The solution is to use gsettings as explained here
gsettings set org.gnome.desktop.wm.keybindings switch-input-source "['<Shift>Alt_L']"
gsettings set org.gnome.desktop.wm.keybindings switch-input-source-backward "['<Alt>Shift_L']"
UPDATE: As mentioned in the comments, make sure to also uncheck the ALT+SHIFT shortcut from gnome-tweak-tool.
Todor
  • 2,428
That was an odd issue. It looks like pressing only Alt is a Skype specific shortcut. Alt+Shift, OTOH, is an XKB shortcut. One way to avoid that Skype is affected is to make sure you press Shift first and then press Alt while still holding the Shift key.
Or, of course, using the default Super+Space is another way to avoid the conflict.
