I have a kingston encryptable USB stick, that when plugged into my laptop gets mounted as read-only.
I have followed the advice given here, but it does not work for me.
I have tried the following:
df -Th
/dev/sr0 iso9660 13M 13M 0 100% /media/user/DTVP
(note that the drive is actually 4GB)
sudo chown user /dev/sr0
sudo chgrp user /dev/sr0
do not yield any output, same if I apply them to /media/user/DTVP
dosfsck /dev/sr0
fsck.fat 4.1 (2017-01-24)
open: Read-only file system
I also tried
getfacl /media/user
getfacl: Removing leading '/' from absolute path names
# file: media/user
# owner: root
# group: root
user::rwx
user:user:r-x
group::---
mask::r-x
other::---
and then try to correct in
sudo setfacl -m u:user:rwx /media/user
but still, the stick stays read-only. Curiously, on Nautilus it appears as a CD rom rather than a USB stick, and, I guess for the same reason, on GParted is not listed and cannot be reformatted.
Any pointers?
Edit: output of journalctl -f
usb 1-3: new high-speed USB device number 5 using xhci_hcd
usb 1-3: New USB device found, idVendor=0951, idProduct=160d, bcdDevice= 1.10
usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-3: Product: DTVault Privacy
usb 1-3: Manufacturer: Kingston
usb 1-3: SerialNumber: XXXXXXXXXXXXXXXXXXXXXXXXXX
usb-storage 1-3:1.0: USB Mass Storage device detected
scsi host1: usb-storage 1-3:1.0
mtp-probe[6223]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3"
mtp-probe[6223]: bus: 1, device: 5 was not an MTP device
baloo_file.desktop[2203]: UdevQt: unhandled device action "bind"
mtp-probe[6239]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-3"
mtp-probe[6239]: bus: 1, device: 5 was not an MTP device
kernel: scsi 1:0:0:0: Direct-Access Kingston DTVault Privacy PMAP PQ: 0 ANSI: 0 CCS
kernel: scsi 1:0:0:1: CD-ROM Kingston DTVault Privacy PMAP PQ: 0 ANSI: 0 CCS
kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
kernel: sr 1:0:0:1: [sr0] scsi3-mmc drive: 0x/0x writer tray
kernel: sr 1:0:0:1: Attached scsi CD-ROM sr0
kernel: sr 1:0:0:1: Attached scsi generic sg1 type 5
kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
kernel: ISO 9660 Extensions: Microsoft Joliet Level 3
kernel: ISO 9660 Extensions: RRIP_1991A
systemd[1]: Started Clean the /media/user/DTVP mount point.
udisksd[1336]: Mounted /dev/sr0 at /media/user/DTVP on behalf of uid 1000
