I just upgraded my HDD to SSD to improve the performance of my system. I followed this guide and it's working well.
But, I think that the boot time is just the same as before. I also searched about it and found some resources to try.
So i reinstalled the NVIDIA drivers, but nothing changed. I also tried to fix the resume thing but I couldn't find the /etc/initramfs-tools/conf.d/resume file.
Here is the output of systemd-analyze time:
Startup finished in 3.982s (firmware) + 10.968s (loader) + 2.105s kernel) + 11.454s (userspace) = 28.510s
graphical.target reached after 9.380s in userspace
lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 5.8M 1 loop /snap/htop/1168
loop1 7:1 0 149.9M 1 loop /snap/gnome-3-28-1804/67
loop2 7:2 0 136.7M 1 loop /snap/code/15
loop3 7:3 0 3.7M 1 loop /snap/gnome-system-monitor/100
loop4 7:4 0 4M 1 loop /snap/gnome-calculator/406
loop5 7:5 0 42.8M 1 loop /snap/gtk-common-themes/1313
loop6 7:6 0 88.5M 1 loop /snap/core/7270
loop7 7:7 0 54.4M 1 loop /snap/core18/1066
loop8 7:8 0 14.8M 1 loop /snap/gnome-characters/296
loop9 7:9 0 1008K 1 loop /snap/gnome-logs/61
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
└─sda2 8:2 0 465.3G 0 part /
cat /etc/fstab output:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during installation
UUID=6ca24650-d418-47c8-8a9b-33c115766285 / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
#UUID=461C-0619 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
UUID=461C-0619 /boot/efi vfat defaults 0 1
If you guys need more info please let me know and thank you in advance.
EDITED
Here is the output of systemd-analyzed blame :
6.175s NetworkManager-wait-online.service
5.039s bolt.service
4.451s plymouth-quit-wait.service
1.289s apparmor.service
1.219s plymouth-read-write.service
1.109s systemd-backlight@backlight:intel_backlight.service
1.095s systemd-logind.service
786ms dev-sda2.device
770ms NetworkManager.service
765ms snapd.service
716ms fwupd.service
668ms systemd-journal-flush.service
644ms snap-gnome\x2dcharacters-296.mount
640ms snap-core18-1066.mount
557ms dev-loop1.device
509ms snap-gnome\x2dlogs-61.mount
487ms dev-loop3.device
456ms dev-loop4.device
410ms mysql.service
404ms snap-core-7270.mount
367ms dev-loop5.device
312ms snap-gtk\x2dcommon\x2dthemes-1313.mount
281ms snap-gnome\x2dsystem\x2dmonitor-100.mount
280ms snap-gnome\x2dcalculator-406.mount
279ms snap-code-15.mount
247ms dev-loop6.device
227ms dev-loop0.device
212ms dev-loop2.device
178ms udisks2.service
178ms apache2.service
166ms ModemManager.service
164ms systemd-udev-trigger.service
149ms networking.service
140ms upower.service
135ms dev-loop9.device
135ms grub-common.service
131ms snap-gnome\x2d3\x2d28\x2d1804-67.mount
128ms apport.service
123ms systemd-rfkill.service
121ms avahi-daemon.service
117ms networkd-dispatcher.service
113ms alsa-restore.service
113ms gpu-manager.service
105ms rsyslog.service
104ms pppd-dns.service
93ms snap-htop-1168.mount
83ms accounts-daemon.service
81ms phpsessionclean.service
71ms wpa_supplicant.service
70ms swapfile.swap
69ms thermald.service
69ms speech-dispatcher.service
65ms bluetooth.service
64ms keyboard-setup.service
55ms systemd-journald.service
55ms systemd-udevd.service
39ms user@1000.service
37ms packagekit.service
36ms systemd-resolved.service
35ms user@121.service
35ms systemd-timesyncd.service
24ms systemd-tmpfiles-clean.service
21ms plymouth-start.service
21ms systemd-fsck@dev-disk-by\x2duuid-461C\x2d0619.service
17ms systemd-tmpfiles-setup-dev.service
17ms gdm.service
13ms systemd-tmpfiles-setup.service
13ms snapd.seeded.service
12ms polkit.service
12ms colord.service
11ms systemd-sysctl.service
9ms dev-hugepages.mount
9ms kmod-static-nodes.service
9ms kerneloops.service
9ms dev-loop8.device
8ms dev-mqueue.mount
7ms systemd-remount-fs.service
7ms ureadahead-stop.service
6ms dns-clean.service
6ms boot-efi.mount
5ms sys-kernel-debug.mount
5ms systemd-update-utmp-runlevel.service
4ms systemd-update-utmp.service
4ms systemd-random-seed.service
3ms sys-kernel-config.mount
3ms systemd-user-sessions.service
3ms systemd-modules-load.service
3ms console-setup.service
3ms rtkit-daemon.service
3ms nvidia-persistenced.service
2ms sys-fs-fuse-connections.mount
2ms setvtrgb.service
2ms snapd.socket
2ms ufw.service
And the SATA version i typed this command
dmesg | grep -i sata | grep 'link up' | tail -n1
The output is here :
[ 1923.391890] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
