How do I make my display grayscale? - alredy tried this tutorial, but the folder name doesn't allow "/" in it.
I've tried doing it through Imagemagick, but couldn't properly install it.
Newbie on Linux. Thanks.
broade
First, install git:
sudo apt update
sudo apt install git
Next, run the following commands to create the proper folder directory:
mkdir -p ~/.local/share/gnome-shell/extensions/
It may state that the directory already exists. You can ignore this error.
Then, run the following command to download the extension:
git clone https://github.com/laerne/desaturate_all.git
Finally, run the following command to move the files to the proper directory:
mv desaturate_all ".local/share/gnome-shell/extensions/desaturate_all@nicolas.brack.mail.be"
Now, you will need to restart Gnome. Press ALT+F2 and then press R and then press ENTER.
You can enable the extension by browsing to https://extensions.gnome.org/local
Click here for more information.
Please post any errors. Thanks!
mchid
  • 44,904
  • 102
  • 162
There is a GNOME Extension for this. You can install this extension with one click form Desaturate All GNOME Extention by laerne. When you install extension, a picture icon appear on the taskbar. When you click, all desktop went to greyscale.
