When I run Ubuntu 16.04 for a long time (let us say minimum overnight, sitting idle) on my ASUS ROG G752VSK laptop, Nautilus repeatedly run into this funny issue, which is described perfectly here:
Cannot rename files or folders in Nautilus
With every reboot, which I try to avoid to let my work steady going on, it works all fine again.
So the main issue is that Nautilus is losing its focus and so in the end I cannot rename files here. For example. Of course all provided solutions in the link are not working, but there is no solution voted up or marked as solved.
Use of my system:
- The only really extensive use is Google Chrome Browser (many tabs and windows), which by the way causes sometimes the "frozen" windows effect, which only affects the actual windows of chrome. Here I can help myself closing the window and reopen it (restore option of the tabs)
- Several remote connections to my raspberry pi and my Synology NAS via terminal and ssh.
- Some open Editors like notepadqq or gedit show similar behaviour
My only question is: Did someone suffices the same behaviour and perhaps knows a root cause for this? As told, it happens only after a really long time of idling, like overnight or so...
[EDIT] Of course I do have a swap partition - it should match my 24 GB RAM, but here is the output of sudo swapon --show:
NAME TYPE SIZE USED PRIO
/dev/dm-0 partition 22,9G 88M -2
