I tried using my audio recently and I noticed that I couldn't any more, I've tried a few of the options I've seen but they do not seem to work:
  1. Dummy Output in Audio; nothing is working (ALSA broken?) This doesn't work, after i run sudo alsa force-reload I get:
Unloading ALSA sound driver modules: (none loaded).
Loading ALSA sound driver modules: (none to reload).
  1. https://askubuntu.com/a/800280/990366 and this too, when i run:
sudo apt-get install --reinstall linux-image-`uname -r`
I get errors that a config is bad:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/8,360 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 182773 files and directories currently installed.)
Preparing to unpack .../linux-image-5.0.0-25-generic_5.0.0-25.26_amd64.deb ...
/etc/kernel/preinst.d/intel-microcode:
libkmod: ERROR ../libkmod/libkmod-config.c:656 kmod_config_parse: /etc/modprobe.d/alsa-base.conf line 44: ignoring bad line starting with 'snd-hda-intel'
Unpacking linux-image-5.0.0-25-generic (5.0.0-25.26) over (5.0.0-25.26) ...
Setting up linux-image-5.0.0-25-generic (5.0.0-25.26) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.0.0-25-generic
I: /initrd.img.old is now a symlink to boot/initrd.img-5.0.0-25-generic
Processing triggers for linux-image-5.0.0-25-generic (5.0.0-25.26) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.0.0-25-generic
I: The initramfs will attempt to resume from /dev/sda8
I: (UUID=b69c28bb-170e-48a4-a279-f4449d689741)
I: Set the RESUME variable to override this.
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.0.0-25-generic
Found initrd image: /boot/initrd.img-5.0.0-25-generic
Found linux image: /boot/vmlinuz-5.0.0-13-generic
Found initrd image: /boot/initrd.img-5.0.0-13-generic
Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
done
and sudo modprobe snd-hda-intel gave me:
modprobe: FATAL: Module snd-hda-intel not found in directory /lib/modules/5.0.0-25-generic
I do not really know what these commands do, It's just been trial and error. This is happening on Ubuntu 19.04.
cat /etc/modprobe.d/alsa-base.conf gave me:
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
# Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio index=-2
options snd-usb-caiaq index=-2
options snd-usb-ua101 index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
snd-hda-intel probe_mask=1
pacmd list-cards gives me: 0 card(s) available.
remove the last line snd-hda-intel probe_mask=1 or change it to options snd-hda-intel probe_mask=1 in /etc/modprobe.d/alsa-base.conf
This ist the right syntax.
If this is your own change, it is better make an own file in /etc/modprobe.d/ with suffix conf. During an upgrade als-base.conf could be overiten.
  1. check with df -h;df -i you have place and free inodes particularly in /boot if it is a own patition. if not try sudo apt-get autoremove --purge. Take a good look, what will be removed, before you "say" yes.
  2. sudo apt install --reinstall linux-modules-5.0.0-25-generic No error?
  3. reboot
If problem persist, show pacmd list-cards expand your question for that.
nobody
  • 5,792
