I don't want a background image on my desktop. Even the color background is a PNG image file. Want just a RGB color pick, or plain background.
Having a background image makes remote desktop too slow.
Ubuntu v19.04
Ubuntu v19.04
this answer is targeted for RGB color option
gsettings get org.gnome.desktop.background picture-uri
Example:
pratap@i7:~$ gsettings get org.gnome.desktop.background picture-uri
'file:///usr/share/backgrounds/contest/bionic.xml'
pratap@i7:~$
gsettings set org.gnome.desktop.background picture-uri ''
gsettings get org.gnome.desktop.background primary-color
Example:
pratap@i7:~$ gsettings get org.gnome.desktop.background primary-color
'#000000'
pratap@i7:~$
gsettings set org.gnome.desktop.background primary-color 'rgb(255, 173, 100)'
Example:
pratap@i7:~$ gsettings set org.gnome.desktop.background primary-color 'rgb(255, 173, 100)'
pratap@i7:~$
other gsettings points to know
gsettings get org.gnome.desktop.background color-shading-type
gsettings get org.gnome.desktop.background secondary-color
Alternatively you can use dconf-editor which can be installed with the below command
sudo apt install dconf-editor
Here are some options for selecting different backgrounds, including using a flat color:
https://help.ubuntu.com/stable/ubuntu-help/look-background.html.en
"You can Change the image used for your backgrounds or set it to be a solid color.
• Select Wallpapers to use one of the many professional background images that ship with GNOME. Some wallpapers change throughout the day. These wallpapers have a small clock icon in the bottom-right corner.
• Select Pictures to use one of your own photos from your Pictures folder. Most photo management applications store photos there. If you would like to use an image that is not in your Pictures folder, either use Files by right-clicking on the image file and selecting Set as Wallpaper, or Image Viewer by opening the image file, clicking the menu button in the titlebar and selecting Set as Wallpaper.
• Select Colors to just use a flat color.
