The moment I lock my PC, the fans get really noisy, which means there has to be some kind of CPU/GPU load behind the scenes.
I told myself, I need to know, what process is doing this, so I've crafted this audit script using top and awk, which basically takes *.csv filename as input and writes there every second 10 most demanding processes.
#!/bin/bash
SLEEP_SECS=1
DESTFILE="$1"
if ! [[ "${DESTFILE}" =~ \.csv$ ]]; then
echo "Please provide name of a destination .csv file!"
exit 1
fi
if ! test -f "${DESTFILE}"; then
echo "Seconds;PID;User;% CPU;Process Name" > "${DESTFILE}" || exit $?
fi
while true; do
top -b -o %CPU -n1 | \
tail -n +8 | \
head -10 | \
awk '{print systime() ";" $1 ";" $2 ";" $9 ";" $12}' \
echo -n .
sleep "${SLEEP_SECS}"
done
So I've started the script and locked my screen, fans got really noisy, I waited a little, logged back in, fans got quiet (as if they knew I don't want them to be noisy when I'm not doing anything with the PC :D ) and I've looked into the processes, which got more than 50% of the CPU usage with this command:
gawk --use-lc-numeric -F';' '{if($4 > 50) {print $0}}' cpu-audit.csv
Here's what I've found:
# The header wasn't there OFC, I'm including it just for the convenience
Seconds ; PID; User ;% CPU;Process Name
1566804437;2496;jirislav;106,7;gnome-shell
1566804438;2496;jirislav;106,7;gnome-shell
1566804439;2496;jirislav;100,0;gnome-shell
1566804440;2496;jirislav;100,0;gnome-shell
1566804442;2496;jirislav;93,8;gnome-shell
1566804443;2496;jirislav;100,0;gnome-shell
1566804444;2496;jirislav;100,0;gnome-shell
1566804445;2496;jirislav;100,0;gnome-shell
1566804446;2496;jirislav;106,7;gnome-shell
1566804449;2496;jirislav;131,2;gnome-shell
1566804449;17446;jirislav;68,8;nautilus
What a surprise, gnome-shell was demanding so much resources? What the ...?! I'm not even using it, I use terminator all the time. Ok, so I ran the terminal audit using ps, but it haven't detected the usage as the top did, why not? I'm even listing all the child processes:
$ while true; do ps fu --ppid 2496 --pid 2496; sleep 1; done
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
jirislav 2496 7.3 2.2 2949284 357176 tty2 Rl+ 08:49 3:02 /usr/bin/gnome-shell
jirislav 2522 0.7 0.0 322108 8800 tty2 Sl 08:49 0:18 \_ ibus-daemon --xim --panel disable
jirislav 3239 1.2 0.4 855328 67956 tty2 Sl+ 08:49 0:30 \_ /usr/bin/python3 /usr/bin/terminato
jirislav 2496 7.3 2.2 2949284 356820 tty2 Sl+ 08:49 3:02 /usr/bin/gnome-shell
jirislav 2496 7.3 2.2 2949284 356820 tty2 Rl+ 08:49 3:03 /usr/bin/gnome-shell
I said enough, let's uninstall gnome-shell, I'm not even using it, why let it consume the resources and run noisy fans without my consent? .. Then it hit me, gnome-shell cannot be uninstalled without also uninstalling ubuntu-desktop - let's put aside the question why there is this weird dependency, which doesn't make sense (it could use any other terminal) - the thing I'm wandering about is - what is Ubuntu doing while my session is locked and can I turn this off?
When I'm on meeting, it's really inconvenient.
Note:
I know about the question Ubuntu 18.04 gnome-shell high CPU usage, but none of the proposed solutions work (not that I even expected them to work, because the issue is that mine gnome-shell is using too much resources only when I lock the PC - not when I use it as the linked question describes)
