After upgrading to 19.04 from 18.10 - I've started seeing an error revolving around linux-image-4.18.0-24-generic and seems to cause me from updates as well updating grub of course... Has anyone experienced this or can anyone guide me as to how to repair this issue?
After running this command sudo apt update && sudo apt upgrade I then receive this error in the terminal:
"Do you want to continue? [Y/n] y
(Reading database ... 238003 files and directories currently installed.)
Removing linux-image-4.18.0-24-generic (4.18.0-24.25) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-4.18.0-24-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
using custom appearance settings
/etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-4.18.0-24-generic (--remove):
installed linux-image-4.18.0-24-generic package post-removal script subprocess returned error exit status 1
Also when attempting to do a partial upgrade it says that kernel isnt installed and fails out
UPDATE: As requested I am posting the output of each command here
dpkg -S /etc/grub.d/bin/grubcfg_proxy
dpkg-query: no path found matching pattern /etc/grub.d/bin/grubcfg_proxy
ldd /etc/grub.d/bin/grubcfg_proxy
linux-vdso.so.1 (0x00007ffe12df1000)
libcrypto.so.1.0.0 => not found
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f4ed9660000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f4ed9646000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4ed945b000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4ed930d000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4ed9867000)
apt-cache policy grub-customizer - **grub-customizer:
Installed: 5.1.0-1
Candidate: 5.1.0-1
Version table:
* 5.1.0-1 500
500 http://it-mirrors.evowise.com/ubuntu disco/universe amd64 Packages
100 /var/lib/dpkg/status
which grub-customizer
/usr/bin/grub-customizer
Update 2: After moving both files as suggested here the output of
sudo apt-get upgrade is:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 8,573 kB disk space will be freed.
(Reading database ... 237928 files and directories currently installed.)
/etc/grub.d/21_memtest86+_proxy: 3: /etc/grub.d/21_memtest86+_proxy: /etc/grub.d/bin/grubcfg_proxy: not found
Found memtest86+ image: /boot/memtest86+.elf
