Recently, I have clicked on the upgrade button to upgrade to Ubuntu 20.04 from 18.04. I think the upgrade didn't finish installing everything for some reason...
The system works fine but, every time I try using apt I get the following errors:
xyz@xyz-laptop:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be REMOVED
linux-image-4.15.0-154-generic
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 8,485 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 211024 files and directories currently installed.)
Removing linux-image-4.15.0-154-generic (4.15.0-154.161) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-4.15.0-154-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.4.0-84-generic
Found initrd image: /boot/initrd.img-5.4.0-84-generic
Found linux image: /boot/vmlinuz-4.15.0-156-generic
Found initrd image: /boot/initrd.img-4.15.0-156-generic
Found linux image: /boot/vmlinuz-4.15.0-112-generic
Found initrd image: /boot/initrd.img-4.15.0-112-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
Found Windows Recovery Environment on /dev/sda3
Found Windows Recovery Environment on /dev/sda8
/etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-4.15.0-154-generic (--remove):
installed linux-image-4.15.0-154-generic package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
I wonder if anyone has any idea about what I can do to solve this issue as I am not sure if I have any backup?
EDIT: More details:
xyz@xyz-laptop:~$ dpkg -l | egrep -v '^ii|rc'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
rH linux-image-4.15.0-154-generic 4.15.0-154.161 amd64 Signed kernel image generic
