I was basically doing the same thing as this guy, but haven't been as lucky. When I got to the same step in the same tutorial, I also had errors, and as that thread was the only thing that seemed relevant, I updated from 16.04.x LTS to 18.04.3 LTS.
Unfortunately, the upgrade not only failed to resolve my problems, but also introduced new ones. Specifically, mouse and keyboard input at the login screen are now very choppy (mouse moves and freezes, several keypresses appear at once and then none for a brief period with some lost if the buffer is exceeded). The issue goes away after I log in using default settings, but if I click the gear icon during login and choose Ubuntu on Wayland, the choppiness continues inside my login session. This seems likely to indicate a Wayland problem that needs resolved.
In the meantime, in case it is useful, here is the terminal output when I run "sudo miral-app" while logged in using X (presumably, but specifically, the "Ubuntu" option vs the "Ubuntu on Wayland" option):
[2019-08-14 13:33:35.752191] <information> mirserver: Starting
[2019-08-14 13:33:35.752288] < - debug - > mirserver: Not trying logind: "DISPLAY" is set and X need not have claimed the VT
[2019-08-14 13:33:35.752527] < - debug - > mirserver: Using Linux VT subsystem for session management
[2019-08-14 13:33:35.752611] <information> mircommon: Loading modules from: /usr/lib/x86_64-linux-gnu/mir/server-platform
[2019-08-14 13:33:35.752647] <information> mircommon: Loading module: /usr/lib/x86_64-linux-gnu/mir/server-platform/server-mesa-x11.so.16
[2019-08-14 13:33:35.752665] <information> mircommon: Loading module: /usr/lib/x86_64-linux-gnu/mir/server-platform/graphics-mesa-kms.so.16
[2019-08-14 13:33:35.752679] <information> mircommon: Loading module: /usr/lib/x86_64-linux-gnu/mir/server-platform/input-evdev.so.7
[2019-08-14 13:33:35.753943] <information> mirplatform: Found graphics driver: mir:mesa-x11 (version 1.4.0) Support priority: 0
[2019-08-14 13:33:35.754644] <information> mesa-kms: EGL platform does not support EGL_KHR_platform_gbm extension
[2019-08-14 13:33:35.754816] <information> mesa-kms: Failed to claim DRM master: Invalid argument
[2019-08-14 13:33:35.754878] <information> mirplatform: Found graphics driver: mir:mesa-kms (version 1.4.0) Support priority: 0
ERROR: /build/mir-4z9EK5/mir-1.4.0/src/server/graphics/default_configuration.cpp(172): Throw in function mir::DefaultServerConfiguration::the_graphics_platform()::<lambda()>
Dynamic exception type: boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::runtime_error> >
std::exception::what: Exception while creating graphics platform
ERROR: /build/mir-4z9EK5/mir-1.4.0/src/platform/graphics/platform_probe.cpp(109): Throw in function std::shared_ptr<mir::SharedLibrary> mir::graphics::module_for_device(const std::vector<std::shared_ptr<mir::SharedLibrary> >&, const mir::options::ProgramOption&, const std::shared_ptr<mir::ConsoleServices>&)
std::exception::what: Failed to find platform for current system
waiting for wayland-0
Note that the "waiting for wayland-0" output seems to repeat endlessly if I don't terminate using CTRL+C. The output may have been the same in 16.04.x, but I didn't record it. Further, I see similar output when running the same command while logged in using the Ubuntu on Wayland setting, but the repeating message is then "waiting for wayland-1". I haven't recorded that output, either, but it is repeatable, so I can if it would be useful.
Where do I need to go and/or what do I need to do to troubleshoot this issue?
ETA: Graphics card in this system is "Aspeed AST2400 BMC"
rpseu
  • 121
There appear to be several issues here. But none of them seem to be the same as the post you linked to. Starting at the beginning:
  1. The step in the tutorial asks you to run: miral-app -kiosk -launcher 'glmark2-wayland' not "sudo miral-app".
If that also fails, then post the log from that.
  1. In the above log Mir is not given control of the graphics hardware. Please indicate what that hardware is, and if you have installed any vendor drivers.
