40
There are multiple virtual machines running Ubuntu and they are all updated by the following command:
apt-get update
apt-get upgrade
But updating each VM separately takes a lot of time to download the required packages and also uses massive amount of bandwidth (which I'm running out of). Is it possible to transfer the updated files by apt-get directly into VMs?
I know the packages are stored in /var/cache/apt/archives but I need the apt-get database files (list of mirrors, indexes, available packages on mirrors, ...)
Update: There are many solutions
  1. apt-cacher-ng as mentioned in the answers.
  2. Docker images built for caching apt files (they run squid actually)
  3. Simply using squid
Also, as mentioned in the answers, see Best way to cache apt downloads on a LAN?
hkoosha
  • 698
5 Answers5
54
The .deb-files you have allready downloaded are stored in /var/cache/apt/archives/.
turbo
  • 4,712
18
/var/cache/apt/archives is where they should be stored.
Naftuli Kay
  • 4,344
17
Not an explicit answer to your question, but have you considered setting up an apt proxy? I use apt-cacher-ng (apt-get install apt-cacher-ng). Prehaps set this up on the VM host, and tell the VMs (and the host) to use this as their proxy (as simple as adding a file (eg 02proxy) to /etc/apt/apt.conf.d/ containing
Acquire::http { Proxy "http://vm host ip:3142"; };
That way you can just do apt-get upgrade without having to manually copy file around. When one computer downloads the debs they will be stored on the proxy for the next computer that requests it. Can handle multiple releases and different architectures, etc
cosmorogers
  • 657
Quick instructions to create a local apt archive using a convenient debian tool called "apt-ftparchive"
Example, create /home/aptcache as local directory to store *.deb files to install in future without repeat download and wasting bandwidth:
# Create the directory
mkdir /home/aptcache
Copy debs already downloaded to your system:
cp /var/cache/apt/archives/* /home/aptcache/
Scan the local packages into local database
cd /home/atpcache apt-ftparchive packages . > Packages apt-ftparchive release . > Release
Add this line to /etc/apt/sources.list (I placed at top)
deb [allow-insecure=yes] file:/home/aptcache ./
Update apt
apt-get update
Now you can install the package normally. If apt-get asks "Install these packages without verification?", answer "Y" to install. That's because this local repository is not signed.
You can also install all packages in your new local apt archive in one simple command
  apt-get install aptcache
source information: https://wiki.debian.org/DebianRepository/Setup#Quick_instructions_to_create_a_trivial_local_archive_with_apt-ftparchive
(acknowledgement to Debian team!)
Lorenz Keel
  • 9,511
You can backup all the *.deb, then copy it into vmware, you can copy it in /root/sw_backup. The folder can not be /var/cache/apt/archives/.
Then you can locally install it with synaptic. $synaptic "file" menu to find local install. but it also needs network, just need to update a little package.
nsane
  • 486
