I am using Ubuntu 18.04 and want to install cuda library. But it kept failing so I deleted it all and reinstalled the Ubuntu 18.04. So how can I install cuda libraries on this? Also, when I type in nvidia-smi on the terminal window I can see the name of the GPU. Thank you!
Asked
Active
Viewed 616 times
Open the terminal and type:
sudo apt update
sudo ubuntu-drivers install
sudo apt install nvidia-cuda-toolkit
sudo reboot
After rebooting run the following command to show what Nvidia driver version is installed:
apt policy nvidia-driver-390 nvidia-driver-430
If nvidia-driver-390 is installed run the following command:
sudo apt install nvidia-compute-utils-390
If nvidia-driver-430 is installed run the following command:
sudo apt install nvidia-compute-utils-430
karel
- 122,292
- 133
- 301
- 332
