I am trying to install nvidia-docker (https://github.com/NVIDIA/nvidia-docker) and when I run:
sudo apt-get install -y nvidia-container-toolkit
I get:
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
cuda-drivers : Depends: nvidia-compute-utils-418 (>= 418.67) but it is not going to be installed
Depends: nvidia-dkms-418 (>= 418.67) but it is not going to be installed
Depends: nvidia-driver-418 (>= 418.67) but it is not going to be installed
Depends: nvidia-kernel-common-418 (>= 418.67) but it is not going to be installed
Depends: nvidia-kernel-source-418 (>= 418.67) but it is not going to be installed
Depends: nvidia-utils-418 (>= 418.67) but it is not going to be installed
Depends: xserver-xorg-video-nvidia-418 (>= 418.67) but it is not going to be installed
libnvidia-gl-418 : Depends: libnvidia-gl-430 but it is not going to be installed
libnvidia-ifr1-430 : Depends: libnvidia-gl-430 but it is not going to be installed
nvidia-container-toolkit : Depends: libnvidia-container-tools (>= 0.1.0) but it is not going to be installed
Depends: libnvidia-container-tools (< 2.0.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Now if I do:
sudo apt --fix-broken install
I get:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
lib32gcc1 libc6-i386 ocl-icd-libopencl1 xserver-xorg-legacy
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-cfg1-430 libnvidia-gl-430 nvidia-compute-utils-418 nvidia-compute-utils-430 nvidia-dkms-418 nvidia-dkms-430 nvidia-driver-418 nvidia-driver-430
nvidia-kernel-common-418 nvidia-kernel-common-430 nvidia-kernel-source-418 nvidia-kernel-source-430 nvidia-utils-418 nvidia-utils-430
xserver-xorg-video-nvidia-418 xserver-xorg-video-nvidia-430
Recommended packages:
libnvidia-compute-430:i386 libnvidia-decode-430:i386 libnvidia-encode-430:i386 libnvidia-ifr1-430:i386 libnvidia-fbc1-430:i386 libnvidia-gl-430:i386
The following packages will be REMOVED:
nvidia-418 nvidia-418-dev
The following NEW packages will be installed:
0 upgraded, 16 newly installed, 2 to remove and 11 not upgraded.
6 not fully installed or removed.
Need to get 0 B/47.2 MB of archives.
After this operation, 228 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 117044 files and directories currently installed.)
Preparing to unpack .../libnvidia-gl-430_430.40-0ubuntu0~gpu18.04.1_amd64.deb ...
Unpacking libnvidia-gl-430:amd64 (430.40-0ubuntu0~gpu18.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-430_430.40-0ubuntu0~gpu18.04.1_amd64.deb (--unpack):
trying to overwrite '/usr/share/glvnd/egl_vendor.d/10_nvidia.json', which is also in package nvidia-418 418.67-0ubuntu1
and the problem doesn't solve.
I've tried several things: install everything with the -f parameter, trying to purge the cuda drivers, install aptitude, but all of them give me dependencies error. For example, if I try to install aptitude, (with sudo apt-get install aptitude) I get:
aptitude : Depends: aptitude-common (= 0.8.10-6ubuntu1) but it is not going to be installed
Depends: libboost-filesystem1.65.1 but it is not going to be installed
Depends: libboost-iostreams1.65.1 but it is not going to be installed
Depends: libboost-system1.65.1 but it is not going to be installed
Depends: libcwidget3v5 but it is not going to be installed
Depends: libsigc++-2.0-0v5 (>= 2.8.0) but it is not going to be installed
Depends: libxapian30 but it is not going to be installed
Recommends: libparse-debianchangelog-perl but it is not going to be installed
which of course doesn't get fixed with the suggested apt --fix-broken install.
I've got installed the CUDA drivers version 10.1:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Apr_24_19:10:27_PDT_2019
Cuda compilation tools, release 10.1, V10.1.168
if that helps.
Any help would be much appreciated. Thanks!
