I have a 3840x2160 built-in monitor and one external monitor on the left side with 1280x1024 resolution. The built-in monitor is perfect for me with 200% scale. However, the external monitor has the same 200% scale which everything is magnified. Is there a way to have a different scale for these monitors? (100% for the external and 200% for the built-in one.)
Thanks
vortex
  • 13
I had the same question today, the answer from travis-wayland helped me Different display scale settings - 18.04
the xrand setting he gives is for 1600x900 monitor - you need to adjust for your resolution
here his answer:
Go to setting > displays > set scale to 200%
Connect to dell monitor, type xrandr to check for id of two monitors. Here I assume you have monitor 'HDMI-0' of 3840x2160, monitor 'HDMI-1' of 1600x900. Now I want to place 'HDMI-1' to left, 'HDMI-0' to right.
Run the following
xrandr --dpi 276 --fb 7040x2160 --output HDMI-0 --mode 3840x2160 --pos 3200x0 --output HDMI-1 --scale 2x2 --panning 3200x1800+0+0
(Note: 7040 = 3840+1600x2, 3200=1600x2, 1800=900x2)
jeff
  • 309
In my case, I used the following command and it worked perfectly:
xrandr --output DP-1 --scale 2x2
Just replace the name to your relevant screen name (in my case its DP-1). You can check it by simply write
xrandr
