I've been slamming my head over this issue. According to previous up-voted methods: askubuntu_link1 and similarly askubuntu_link2, I enable power/wakeup to the usb device connected to my wireless mouse receiver and also attempt to create udev rules for my specific device. However, I still can't get any wakeup response from my wireless mouse upon suspend; I'm only able to wake up by opening the laptop lid and wake using the touchpad. My laptop is a Dell XPS 13 9380 with Ubuntu 18.04.
I begin:
$ grep . /sys/bus/usb/devices/*/power/wakeup
Initially yielding,
/sys/bus/usb/devices/1-7/power/wakeup:disabled
/sys/bus/usb/devices/1-9/power/wakeup:disabled
/sys/bus/usb/devices/5-1/power/wakeup:disabled
/sys/bus/usb/devices/6-1.2/power/wakeup:disabled
/sys/bus/usb/devices/6-1/power/wakeup:disabled
/sys/bus/usb/devices/usb1/power/wakeup:disabled
/sys/bus/usb/devices/usb2/power/wakeup:disabled
/sys/bus/usb/devices/usb3/power/wakeup:disabled
/sys/bus/usb/devices/usb4/power/wakeup:disabled
/sys/bus/usb/devices/usb5/power/wakeup:disabled
/sys/bus/usb/devices/usb6/power/wakeup:disabled
Finding the usb port for my wireless receiver:
$ lsusb
Bus 006 Device 004: ID 0480:a006 Toshiba America Inc External Disk 1.5TB
Bus 006 Device 003: ID 0bda:8153 Realtek Semiconductor Corp.
Bus 006 Device 002: ID 0424:5807 Standard Microsystems Corp.
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 004: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 005 Device 003: ID 0bda:4014 Realtek Semiconductor Corp.
Bus 005 Device 002: ID 0424:2807 Standard Microsystems Corp.
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0489:e0a2 Foxconn / Hon Hai
Bus 001 Device 002: ID 0c45:6723 Microdia
I identify my device ID is c534.
Find the port my device is plugged into:
$ grep c534 /sys/bus/usb/devices/*/idProduct
/sys/bus/usb/devices/1-9/idProduct:c534
This indicates my device is plugged into bus 1, port 9.
Double-check if wakeup is enabled:
$ cat /sys/bus/usb/devices/1-9/power/wakeup
disabled
Enable wakeup on port:
$ sudo sh -c 'echo "enabled" > /sys/bus/usb/devices/1-9/power/wakeup'
Check if wakeup enabled: $ cat /sys/bus/usb/devices/1-9/power/wakeup enabled
Upon testing the computer in suspend mode, I get no wake up.
Then, I attempt editing wakeup rules specific to my device:
$ lsusb | grep Receiver
Bus 001 Device 004: ID **046d:c534** Logitech, Inc. Unifying Receiver
Using device id's, I edit number 10 priority udev rules for usb port 1-9:
$ sudo nano /etc/udev/rules.d/10-wakeup.rules
ACTION=="add", SUBSYSTEM=="usb", ATTRS{idVendor}=="046d", ATTRS{idProduct}=="c534" RUN+="/bin/sh -c 'echo enabled > /sys/bus/usb/devices/1-9/power/wakeup'"
After system restart, and checking that port 1-9 has wakeup enabled, I continue to get no response from my mouse under computer suspend. WHY??? I'm stuck.
