I used to have Ubuntu 16.04 and I always could play DVDs with VLC. However, after an update to 18.04 I cannot do that anymore.
I have already tried the following:
sudo apt install ubuntu-restricted-extras
sudo apt install libavcodec-extra
sudo apt install libdvd-pkg
sudo dpkg-reconfigure libdvd-pkg
I have also installed libdvdread4 and libdvdnav4 and libdvdcss2.
But when after I put the disc in and try to load it in VLC, I see the opening screen of the DVD for a few seconds after which it disappears again.
Can anyone help? thanks!
this is what appears in the terminal:
katrien@katrien-ThinkPad-T400:~$ vlc VLC media player 3.0.4 Vetinari (revision 3.0.4-0-gf615db6332) [000055c5a5985570] main libvlc: Vlc draait met de standaardinterface. Gebruik 'cvlc' om vlc zonder interface te gebruiken. [000055c5a59894e0] main playlist: playlist is empty libdvdnav: Using dvdnav version 6.0.0 libdvdread: Attempting to use device /dev/sr0 mounted on /media/katrien/NAAR_BUITEN for CSS authentication libdvdnav: Can't read name block. Probably not a DVD-ROM device. libdvdnav: vm: dvd_read_name failed libdvdnav: DVD disk reports itself with Region mask 0x00400000. Regions: 1 2 3 4 5 6 8 libdvdread: Attempting to retrieve all CSS keys libdvdread: This can take a _long_ time, please be patient libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000134 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x000001ab libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00000c7e libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x001034fd libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x0010354a libdvdread: Elapsed time 0 libdvdread: Found 2 VTS's libdvdread: Elapsed time 0 libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libdvdnav: Language 'en' not found, using 'nl' instead libdvdnav: Menu Languages available: nl libva info: VA-API version 1.1.0 libva info: va_getDriverName() returns 0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so libva info: Found init function __vaDriverInit_1_1 libva info: va_openDriver() returns 0 [00007f2c9c06d5f0] vaapi generic error: config doesn't support forced fourcc Failed to open VDPAU backend libvdpau_i965.so: kan gedeeld objectbestand niet openen: Bestand of map bestaat niet [00007f2c9804a370] main decoder error: buffer deadlock prevented Drijvendekomma-berekeningsfout (geheugendump gemaakt) katrien@katrien-ThinkPad-T400:~$ ^C katrien@katrien-ThinkPad-T400:~$ ^C katrien@katrien-ThinkPad-T400:~$
katrien@katrien-ThinkPad-T400:~$ dpkg -l | grep vdpau ii libvdpau1:amd64 1.1.1-3ubuntu1 amd64 Video Decode and Presentation API for Unix (libraries) ii mesa-vdpau-drivers:amd64 19.0.2-1ubuntu1.1~18.04.2 amd64 Mesa VDPAU video acceleration drivers ii vdpau-driver-all:amd64 1.1.1-3ubuntu1 amd64 Video Decode and Presentation API for Unix (driver metapackage) ii vdpau-va-driver:amd64 0.7.4-6ubuntu1 amd64 VDPAU-based backend for VA API katrien@katrien-ThinkPad-T400:~$ ^C katrien@katrien-ThinkPad-T400:~$
