Question: can you recommend an external DVD player that I can use for watching legal movies in Europe (region code: 2) using Ubuntu 18.04?
I bought a new notebook and an external DVD player because it didn't have one. I installed Ubuntu and installed all the necessary libdvd* packages:
ii libdv4:amd64 1.0.0-11
ii libdvbpsi10:amd64 1.3.2-1
ii libdvd-pkg 1.4.2-1-1
ii libdvdcss-dev:amd64 1.4.2-1~local
ii libdvdcss2:amd64 1.4.2-1~local
ii libdvdnav4:amd64 6.0.0-1
ii libdvdread4:amd64 6.0.0-1
ii ubuntu-restricted-extras 66
ii regionset 0.1-3.1
Then I wanted to play a DVD and got 3 pages of error messages:
$ vlc dvd://sr0
VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
libdvdnav: Using dvdnav version 6.0.0
libdvdnav: DVD Title: VENOM_2018
libdvdnav: DVD Serial Number: 4d9292d9
libdvdnav: DVD Title (Alternative):
libdvdnav: DVD disk reports itself with Region mask 0x00e50000. Regions: 2 4 5
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x00000167
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x000002f5
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x0000d271
libdvdread: Get key for /VIDEO_TS/VTS_15_0.VOB at 0x002dade8
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_15_0.VOB (0x002dade8)
libdvdread: Get key for /VIDEO_TS/VTS_15_1.VOB at 0x002daf42
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_15_1.VOB (0x002daf42)!!
libdvdread: Found 15 VTS's
libdvdread: Invalid IFO for title 14 (VTS_14_0.BUP).
libdvdread: Can't seek to block 2993628
libdvdread: Can't seek to block 2997149
libdvdread: Invalid IFO for title 15 (VTS_15_0.BUP).
libdvdread: Can't seek to block 2963152
libdvdread: Invalid IFO for title 12 (VTS_12_0.IFO).
libdvdnav: ifoOpenVTSI failed
Then I connected the external DVD to my old notebook which has an internal DVD. I was able to play the DVD by the internal one but the external returned the same error messages.
Device:
$ dmesg | grep -i dvd
[ 5164.196463] scsi 2:0:0:0: CD-ROM HL-DT-ST DVDRAM GP57ES40 PF01 PQ: 0 ANSI: 0
[ 5164.220633] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
$ sudo lshw -C disk
*-cdrom
description: DVD-RAM writer
product: DVDRAM GP57ES40
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: PF01
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: status=ready
*-medium
physical id: 0
$ ls -l sr0
brw-rw----+ 1 root cdrom 11, 0 Nov 8 19:11 sr0
- No disc menus:
I delete the folder related to the movie inside the ~./dvdcss folder.
I ticked the No disc menus checkbox in the VLC UI then it played the DVD but it stoped when it reached 19:18 dvdread demux error: read failed for 3/4 blocks at 0x72d80
I tried to play it from command line without disc menu and it also worked: vlc dvdsimple://sr0
Then I tried to play it defining the title and the chapter but it always played the first title:
vlc dvdsimple://sr0@01
vlc dvdsimple://sr0@02
I tried to list the titles and the chapters but it resulted the same output when I tried to play it:
$ lsdvd /dev/sr0
libdvdread: Can't seek to block 2676815
libdvdread: Can't seek to block 2678061
libdvdread: Invalid IFO for title 2 (VTS_02_0.BUP).
Segmentation fault (core dumped)
- I changed the regioncode to 2 (I live in Europe) by the
regionsetpackage. Didn't help.
$ regionset /dev/sr0
regionset version 0.1 -- reads/sets region code on DVD drives
Current Region Code settings:
RPC Phase: II
type: SET
vendor resets available: 4
user controlled changes resets available: 4
drive plays discs from region(s): 2, mask=0xFD
Would you like to change the region setting of your drive? [y/n]:n
I checked the values of the
DVDCSS_METHOD. It was empty. I changed it totitle,discandkey. None of them helped.Enables libvdpau-va-gl as the default VDPAU driver didn't help either.
I installed
mplayer,mplayer-guiandmencoder. Fixed the GUI error and tried to play the DVD.
$ mplayer dvd://
It recognized the chapters differently (see the Error cracking CSS key things):
Playing dvd://.
There are 41 titles on this DVD.
There are 1 angles in this DVD title.
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x0028d858
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_02_0.VOB (0x0028d858)
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x0028d9b2
libdvdread: Error cracking CSS key for /VIDEO_TS/VTS_02_1.VOB (0x0028d9b2)!!
It played the first 4 chapters of the DVD till it reached the very same moment in the film when it crashed. Interesting is that the timestamp was 40 seconds more like 19:50:
The error:
MPlayer interrupted by signal 2 in module: decode_video
A: 369.6 V: 369.6 A-V: -0.021 ct: 0.059 9237/9237 7% 1% 2.3% 0 0
The situation is same if I try to play other DVDs. Is it an encoding, a driver or a hardware error?
Do you have any ideas how can I fix it? Or do you have an external DVD player which works for you?
