We can see that at the very least xdotool getactivewindow getwindowname works as intended.
$ wmctrl -r :ACTIVE: -N "Test1"
$ xdotool getactivewindow getwindowname
Test1
$ xdotool getactivewindow set_window --name Test2
Test2
So let's go deeper. We can list properties of window using xprop -id <id> command. For window with name set by wmctrl it gives:
_NET_WM_OPAQUE_REGION(CARDINAL) = 0, 0, 1920, 995
_NET_STARTUP_ID(UTF8_STRING) = "brisk-menu-2514-mariusz-HP-Pavilion-Notebook-mate-terminal-1_TIME1314631"
WM_WINDOW_ROLE(STRING) = "mate-terminal-window-4442-66103825-1563868224"
_NET_WM_WINDOW_TYPE(ATOM) = _NET_WM_WINDOW_TYPE_NORMAL
_NET_WM_SYNC_REQUEST_COUNTER(CARDINAL) = 79691784, 79691785
_NET_WM_USER_TIME_WINDOW(WINDOW): window id # 0x4c00007
WM_CLIENT_LEADER(WINDOW): window id # 0x4c00001
_NET_WM_PID(CARDINAL) = 4442
WM_LOCALE_NAME(STRING) = "en_US.UTF-8"
WM_CLIENT_MACHINE(STRING) = "mariusz-HP-Pavilion-Notebook"
WM_NORMAL_HINTS(WM_SIZE_HINTS):
program specified minimum size: 345 by 141
program specified resize increment: 9 by 20
program specified base size: 16 by 30
window gravity: NorthWest
WM_PROTOCOLS(ATOM): protocols WM_DELETE_WINDOW, WM_TAKE_FOCUS, _NET_WM_PING, _NET_WM_SYNC_REQUEST
WM_CLASS(STRING) = "mate-terminal", "Mate-terminal"
_NET_WM_ICON_NAME(UTF8_STRING) = "Terminal"
_NET_WM_NAME(UTF8_STRING) = "Test1"
And for for window with name set by xdotool it gives:
_NET_WM_NAME(STRING) = "Test2"
And we can see that in both cases _NET_WM_NAME is set correctly. What is _NET_WM_NAME? It's an extension for x11 (link, link)
_NET_WM_NAME
_NET_WM_NAME, UTF8_STRING
The Client SHOULD set this to the title of the window in UTF-8 encoding. If set, the Window Manager should use this in preference to
WM_NAME.
So x11 applications should prefer this property over WM_NAME. Let's display both of these properties. I've taken C code from here:
#include <X11/Xlib.h>
#include <X11/Xatom.h>
#include <stdio.h>
#include <stdlib.h>
#define MAXSTR 1000
Display *display;
unsigned long window;
unsigned char *prop;
void check_status(int status, unsigned long window)
if (status == BadWindow) {
printf("window id # 0x%lx does not exists!", window);
exit(1);
if (status != Success) {
printf("XGetWindowProperty failed!");
exit(2);
unsigned char* get_string_property(char* property_name)
Atom actual_type, filter_atom;
int actual_format, status;
unsigned long nitems, bytes_after;
filter_atom = XInternAtom(display, property_name, True);
status = XGetWindowProperty(display, window, filter_atom, 0, MAXSTR, False, AnyPropertyType,
&actual_type, &actual_format, &nitems, &bytes_after, &prop);
check_status(status, window);
return prop;
unsigned long get_long_property(char* property_name)
get_string_property(property_name);
unsigned long long_property = prop[0] + (prop[1]<<8) + (prop[2]<<16) + (prop[3]<<24);
return long_property;
int main(int argc, char** argv)
char *display_name = NULL; // could be the value of $DISPLAY
display = XOpenDisplay(display_name);
if (display == NULL) {
fprintf (stderr, "%s: unable to open display '%s'\n", argv[0], XDisplayName (display_name));
int screen = XDefaultScreen(display);
window = RootWindow(display, screen);
window = get_long_property("_NET_ACTIVE_WINDOW");
printf("_NET_WM_PID: %lu\n", get_long_property("_NET_WM_PID"));
printf("WM_CLASS: %s\n", get_string_property("WM_CLASS"));
printf("_NET_WM_NAME: %s\n", get_string_property("_NET_WM_NAME"));
printf("WM_NAME: %s\n", get_string_property("WM_NAME"));
XCloseDisplay(display);
return 0;
Only added a printf("WM_NAME: %s\n", get_string_property("WM_NAME")); line. Running:
$ gcc test.c -o test -lX11
$ ./test
_NET_WM_PID: 4442
WM_CLASS: mate-terminal
_NET_WM_NAME: Test1
WM_NAME: (null)
$ ./test
_NET_WM_PID: 4442
_NET_WM_NAME: Test2
WM_NAME: Test2
So the conclusion is: xdotool sets both _NET_WM_NAME and WN_NAME but only search by WM_NAME and wmctrl sets only _NET_WM_NAME.
