In previous versions of Ubuntu, like 14.04, it was possible to set the title of each terminal tab via the menu: Terminal -> Set Title ...
In 18.04, there is still the entry Terminal with options like Set Character Encoding, but Set Title is missing.
So how can I set the title in newer versions?
false
  • 1,762
This function is removed since gnome 3
But, the gnome 2 terminal has been forked as mate-terminal, it has the function you want.
sudo apt-get install mate-terminal
If you want to keep the gnome 3 terminal and agree to rename tabs from command line, you can try this:
1- Add a function 'set-title' to the .bashrc
2- Rename a terminal title with set-title The New Title Name
nano ~/.bashrc
##Add the following to the .bashrc file
function set-title() {
  if [[ -z "$ORIG" ]]; then
    ORIG=$PS1
  fi
  TITLE="\[\e]2;$*\a\]"
  PS1=${ORIG}${TITLE}
Usage : set-title My Tab Title
cmak.fr
  • 8,976
In Ubuntu 20.04
PS1=$PS1"\[\e]0;New_Terminal_Name\a\]"
\[ begin a sequence of non-printing characters
\e]0; is the char sequence for setting the terminal title. Bash identifies this sequence and set the tile with the following characters. Number 0 turns out to be the value to reference the title property.
New_Terminal_Name is the tile we gave
\a is the ASCII bell character, also in this case, it marks the end of the tile to read from Bash.
\] end a sequence of non-printing characters
Abhi25t
  • 131
I use xttitle (in the xttitle package):
update_title()
    [[ $TERM = xterm ]] || [[ $TERM = xterm-color ]]  && xttitle "[$$] ${USER}@${HOSTNAME}:$PWD"
cd()
    [[ -z "$*" ]] && builtin cd $HOME
    [[ -n "$*" ]] && builtin cd "$*"
    update_title
waltinator
  • 37,856
