Possible Duplicate:
Is it possible to boot Ubuntu using the Windows bootloader?
I have installed Ubuntu 12.04 Alpha 2 on a partition separate partition from Windows and was wanting to know how to add the OS to the boot.ini so I can boot into Ubuntu.
Possible Duplicate:
Windows XP? Well...
This has been working since the early days of NT4:
dd if=/dev/sdxY of=/media/fat/linux.bin bs=512 count=1 as root, replace sdxY with your linux partition[boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(5)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="Microsoft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professional (Safe mode)" /BASEVIDEO /SOS c:\CMDCONS\BOOTSECT.DAT="Microsoft Windows XP recovery console" /CMDCONS c:\linux.bin="Grub (loader)"
Your results may vary: Grub2 might need downgrading to Grub 1.x for this to work.
You don't add Ubuntu to boot.ini. You add a windows partition to grub.
If you must do it, it is described here for implementations with bitlocker and TPM.
I use EasyBCD (because i have trouble installing GRUB on a EFI motherboard with fakeraid). There is a free version for noncommercial use at the bottom of the page.
As far as I remember, i set up the windows boot loader to chainload grub. There is a automatic method in EasyBCD, but it didn't work for me.
Instead I made it boot into a legacy GRUB with the following menu.lst:
# NeoSmart NeoGrub Bootloader Configuration File
# This is the NeoGrub configuration file, and should be located at C:\NST\menu.lst
# Please see the EasyBCD Documentation for information on how to create/modify entries:
# http://neosmart.net/wiki/display/EBCD/
# Boot automatically after 0 secs.
timeout 0
# By default, boot the first entry.
default 0
title (hd0,4)
root (hd0,4)
kernel /vmlinuz root=UUID=5827fd40-9b04-4f8a-bb0f-df1612670d89 ro
initrd /initrd.img
Note:
(hd0,4) means that my root partition is on /dev/sda5.
UUID=X is the uuid of this volume. You can find this with sudo blkid.
