I currently run Ubuntu Mate 16.04.6 on both my Thinkpad T430 and my homebuilt desktop machine (hardware continuously upgraded for fifteen years or so), and I'm interested in upgrading to Ubuntu Mate 18.04.2. I started the upgrader on the laptop, and was informed that tens of packages would be removed -- I presume because the upgrader only upgrades built-in packages and the packages in question were versions that weren't compatible with 18.04. The upgrader also disabled the repositories for "third party" packages, presumably for the same reason.
My question is, with a system that's not 100% "box stock" (which probably applies to nearly any install that's not used in a locked-down, IT-administered environment), will the "upgrade to 18.04.2" process be reliable enough to plan on simply updating the repo information for my other required packages (update-sun-java, BOINC, etc.) and reinstalling those, or can I look forward to "it'll take less time to install everything clean"?
In my experience, installing clean and reinstalling third party apps would have me looking forward to spending an entire weekend of free time on each machine, so if the upgrade is dependable, it would be preferred -- but spending two weekends, one upgrading and cleaning up after a broken upgrade, and the next installing the new version clean, with a week unable to use the machine in between, is obviously undesirable.
Zeiss Ikon
  • 5,248
I use this script to clone Ubuntu 16.04 to a new partition:
The script updates grub menu with the new clone version and my original 16.04 version is still there safe and sound.
It takes over an hour to run the do-release-upgrade on the clone so I run it while making dinner or something like that. I check back periodically to see if there is a question to install new configuration file or keep old one.
I keep notes on if I updated configuration file for package A or kept the old one. I do this in the likely event I rerun the cloning script and do-release-upgrade. I do not backup before do-release-upgrade because it is a clone that can simply be recloned. This saves a lot of time.
I will play on the upgraded clone for many hours exploring new features, testing old applications and installing new ones. If some applications broke during the do-release-upgrade I may reboot into the original version and remove them, tweak them or replace them with another application that does the same thing but is more compatible with 18.04.
Over the last year I have repeated the cloning process and performed do-release-upgrade four or five times. I haven't pulled the plug and abandoned 16.04 though. I hope when 20.04 comes out next spring they provide a do-release-upgrade that goes direct from 16.04 to 20.04 so people can skip the 18.04 middle step.
In short it is a good idea to run do-release-upgrade on a clone and repeat the process as many times as necessary. Once done on your live data there is no going back.
