I was hoping someone could help me understand what happened with my Ubuntu server.
I had an issue with it acting odd, I won't go into detail but I restarted the server with this command:
shutdown -r now
When it came back up, I attempted to use screen and was given this error:
No more PTYs. Sorry, could not find a PTY. [screen is terminating]
I found this website which told me this:
http://en.positon.org/post/%5BScreen%5D-No-more-PTYs-Sorry-could-not-find-a-PTY
You have to change /dev/ptmx file permissions:
# ls -l /dev/ptmx
crw-r--r-- 1 root root 5, 2 nov 18 23:28 /dev/ptmx
# chmod a+w /dev/ptmx
# ls -l /dev/ptmx
crw-rw-rw- 1 root root 5, 2 nov 18 23:34 /dev/ptmx
This didn't resolve my issue since I was already at:
Same problem.
So I found this post:
https://superuser.com/questions/302235/no-more-ptys-when-trying-to-start-screen
So, I did what the answer suggested, which was:
# mount devpts /dev/pts -t devpts -o mode=620
And it worked fine.
Anyone know what happened, why, and what the devpts did to fix it? I'm completely lost on this one.
Thank you!
ErocM
  • 531
As far as I can tell, /dev/pts needs to be mounted for screen to work.
tshepang
  • 2,007
nisshh
  • 134
Problem
Tried to use the screen program to connect my lab PC to a Raspberry PI via the USB ports and an RS232 cable.
Ran the command screen /dev/ttyUSB0
Got the following error messages in quick succession.
Cannot access line '/dev/ttyUSB0 for r/w: permission denied
Couldn't find a PTY
Solution
Finally found this idea of adding to the dialout group looking at this post.
Changing permissions on serial port
Ran the command:
sudo usermod -a -G dialout $USER
Restarted the computer and voila, it worked. Was able to use screen program to make the connection.
Hope this helps someone out. Peace.
user68186
  • 37,461
I found this when I ran into the same message. Turns out that I had another application (ZTerm) holding a lock on the device. So, as a tip, make sure that no one else is accessing the device!
Peter
